WTB fuel pump 74 1.8 |
Rick Cabell |
Oct 29 2009, 09:26 AM
Newbie Group: Members Posts: 1 Joined: 20-June 09 From: Burlington, Vt. Member No.: 10,487 Region Association: None |
Where is the best place to buy a fuel pump for a 1974 1.8 liter? They don't seem to be that common.
type47 |
Oct 29 2009, 11:34 AM
List of 914 friendly vendors in no particular order include:
Pelican Parts German Parts and Restoration Automobile Atlanta BusDepot Cip1 Autohausaz (maybe azautohaus) Performance Products/Automotion |
RJMII |
Oct 29 2009, 12:39 PM
Jim McIntosh Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None |
List of 914 friendly vendors in no particular order include: Autohausaz (maybe azautohaus) Automobile Atlanta BusDepot Cip1 German Parts and Restoration Pelican Parts Performance Products/Automotion I beg to differ... that list of vendors appears to be in alphabetical order. (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/welcome.png) !! |
Cap'n Krusty |
Oct 29 2009, 02:58 PM
Because the available pumps, if indeed they ARE available, are relatively expensive, you might want to consider using the 2 port pump common to the '75-'76 914, '75-'79 VW T1, and '75-'91 VW T2. Minor simplification of the plumbing is required, and you must use the later model fuel filter. This conversion means you have a NEW Bosch pump, not a cheap Chinese knockoff (with a horrifying record of reliability) or the unknown quantity of a rebuilt one, and at well under half the price (possibly as low as a third the price!).
The Cap'n |
type47 |
Oct 29 2009, 03:09 PM
List of 914 friendly vendors in no particular order include: Pelican Parts German Parts and Restoration Automobile Atlanta BusDepot Cip1 Autohausaz (maybe azautohaus) Performance Products/Automotion I beg to differ... that list of vendors appears to be in alphabetical order. (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/welcome.png) !! fixed that for ya (IMG:style_emoticons/default/idea.gif) |
ClayPerrine |
Nov 1 2009, 09:08 AM
Life's been good to me so far..... Group: Admin Posts: 15,443 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Because the available pumps, if indeed they ARE available, are relatively expensive, you might want to consider using the 2 port pump common to the '75-'76 914, '75-'79 VW T1, and '75-'91 VW T2. Minor simplification of the plumbing is required, and you must use the later model fuel filter. This conversion means you have a NEW Bosch pump, not a cheap Chinese knockoff (with a horrifying record of reliability) or the unknown quantity of a rebuilt one, and at well under half the price (possibly as low as a third the price!). The Cap'n There is also a German made Peerburg pump that is a replacement for the stock pump. It only has two lines, so you have to take the T fitting out of the plumbing and put a straight piece of hose in, but otherwise it works great. |
Cap'n Krusty |
Nov 1 2009, 10:44 AM
Because the wholesale price of the Pierburg pump is about $70 greater than that of the Bosch, it's unlikely you'll find one for a better price than the Bosch version. Besides that, the Bosch pump fits into the original bracket and uses the same pushon electrical connectors.
The Cap'n |
Rocky |
Nov 1 2009, 12:08 PM
From the cockpit Group: Members Posts: 341 Joined: 24-March 04 From: Gig Harbor,WA Member No.: 1,845 |
I just bent over and purchased a Bosch from Pellican ~$140 ish. This replaces the original after 35 years. Thats pretty good bang for the buck it it goes another 35.
Rocky |
Lo-Fi Version | Time is now: 11th May 2024 - 12:47 AM |
