So you want a bolt in roll cage... check this out, YIKES!!!!!!!!!!!! |
GaroldShaffer |
Oct 29 2009, 09:36 PM
Story: the car ramped up the tire wall, then nose-dived into the turf and flipped lengthwise. The bolted-in roll cage didn't have big enough floor plates and they punched through the floor, completely failing to provide protection to the occupants! Somehow, neither driver nor passenger sustained injury!
Bolt in cage Just another reason why you shuoldn't skimp on safety equipment if you plant to go on ANY track! Take a good look at pciture #8. |
charliew |
Oct 29 2009, 09:53 PM
Thats just a bad installation period wether it's welded or bolted. It's hard to tell how that particular roll cage was fastened to the floor. There can be a well fastened boltin cage. It will require a good pad that has a large surface area to spread the load over a large area on the sheetmetal. Bolted or welded if the pad is large enough I think it will be strong enough. In the case of boltin if a equal size pad is on either side of a single wall sheetmetal floor it will be at least as strong, and probably stronger as the weld will create stress at the sides of the weld bead, as a welded to only one side of the same sheetmetal floor.
steveherman |
Member Group: Members Posts: 380 Joined: 12-September 09 From: Kissimmee Florida Member No.: 10,799 Region Association: South East States |
Story: the car ramped up the tire wall, then nose-dived into the turf and flipped lengthwise. The bolted-in roll cage didn't have big enough floor plates and they punched through the floor, completely failing to provide protection to the occupants! Somehow, neither driver nor passenger sustained injury! Bolt in cage Just another reason why you shuoldn't skimp on safety equipment if you plant to go on ANY track! Take a good look at pciture #8. picture #11 says "look better go faster" and "die while doin it should" be on there doesnt look good now |
plymouth37 |
Oct 29 2009, 10:08 PM
Senior Member Group: Members Posts: 1,825 Joined: 24-May 05 From: Snoqualmie, WA Member No.: 4,138 Region Association: Pacific Northwest |
This is exactly why I am adding a couple bars to triangulate my head hoops.
Being upside-down in a car sucks enough, why add a broken neck into the equation? |
Oct 29 2009, 10:11 PM
Resident German Group: Admin Posts: 41,634 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Pic #8, you can see the tube from the cage sticking out the floorpan! (IMG:style_emoticons/default/unsure.gif)
carr914 |
Oct 29 2009, 10:13 PM
Racer from Birth Group: Members Posts: 118,556 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
Cut the rest of the roof off, put a better cage in it and it's back racin as a convertable
Sleepin |
Oct 30 2009, 01:10 AM
Advanced Member Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains |
jt914-6 |
Oct 30 2009, 06:49 AM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
Looks like it happened at Hallett Motor Racing Circuit in Oklahoma. Coming over the rise coming into the "Bitch" turn. He must have hit the alligators at the top of the rise and lost it. Easy to do there......Have instructed there lots of times. He ramped through two tire walls and catch fence. That is a blind rise and you've got to get lined up just right coming over the top....OR things go wrong fast...... (IMG:style_emoticons/default/w00t.gif)
http://www.youtube.com/watch?v=QqErQxmARlA |
6freak |
Oct 30 2009, 09:04 AM
Story: the car ramped up the tire wall, then nose-dived into the turf and flipped lengthwise. The bolted-in roll cage didn't have big enough floor plates and they punched through the floor, completely failing to provide protection to the occupants! Somehow, neither driver nor passenger sustained injury! Bolt in cage Just another reason why you shuoldn't skimp on safety equipment if you plant to go on ANY track! Take a good look at pciture #8. EPIC FAIL....good eye Andy |
ConeDodger |
Oct 30 2009, 09:15 AM
Apex killer! Group: Members Posts: 23,584 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Rod |
Oct 30 2009, 04:02 PM
Senior Member Group: Members Posts: 616 Joined: 1-January 08 From: Farnham UK Member No.: 8,526 Region Association: England |
Even scarier than this is the cars that run harnesses in a 'normal' car... In an accident like the above with a normal seatbelt your body can move into the space available and possibly avoid injury - if a harness is worn the body is locked in position, so if the roof collapses you can't move to get out of the any of incoming bodywork..
The amount of cars over here that won't be allowed to run without a cage if you have harnesses is great, but unfortunately it's also a 'moddas' first change, which could easily cost your life.. Think about harnesses in your cars and if they actually make 'life saving' sense.. |
Lo-Fi Version | Time is now: 13th May 2024 - 01:30 AM |
