Wiring diagram for Subaru Conversion, I know there is one, but where? |
JJ914GT |
Nov 1 2009, 11:38 AM
Member Group: Members Posts: 171 Joined: 21-May 09 From: Amsterdam Member No.: 10,386 Region Association: Europe |
I'm sure I've read about someone that made or had an easy to read wiring diagram for the Subaru conversion, but cannot find it now,..
My EJ20 STI conversion is finally going somewhere, so might need this in the very near future (IMG:style_emoticons/default/w00t.gif) Hope you can help, thanks!! |
Numbchux |
Nov 1 2009, 12:05 PM
Newbie Group: Members Posts: 33 Joined: 3-September 09 From: Duluth, MN Member No.: 10,758 Region Association: Upper MidWest |
I know Kennedy sells a modified diagram for EJ22s into vanagons.
but I have a ton of diagrams. what year EJ20? |
JJ914GT |
Nov 3 2009, 02:32 PM
sorry for the late reply, just started a new job.
Its a JDM Impreza EJ20 STI engine from 97 - 98. I'll also send you a PM, ecause you might not see this post. |
VOX |
Nov 3 2009, 05:54 PM
Member Group: Members Posts: 129 Joined: 6-February 09 From: rosemead, ca Member No.: 10,027 Region Association: None |
if you happen to have a good wiring diagram for an ej22 NA 91-94 dual port exhaust that would be very helpful.
strawman |
Nov 3 2009, 08:48 PM
Senior Member Group: Members Posts: 881 Joined: 25-January 08 From: Los Osos, CA Member No.: 8,624 Region Association: Central California |
I know Kennedy sells a modified diagram for EJ22s into vanagons. but I have a ton of diagrams. what year EJ20? I'll second that -- the Kennedy diagram is nice because it is a full size blueprint, but it really only focuses on the '90-'94 EJ22. Kennedy charges $20 for the 6' drawing, and I used it when I put a Suby EJ22 in my old Vanagon Syncro Westy and am currently using it for my Suby-Teener (I'm using the EJ22T turbo'd engine, which uses many of the same wires/sensors as its normally-aspired cousin). The factory Suby manual is also good; you can also find these at: http://www.main.experiencetherave.com/suba...cans/FSM_Scans/ These manuals focus on the US Suby cars; you might want to make inquiries on the http://www.nasioc.com website. The Haynes 914 diagram is very basic, but the diagrams on the Pelican website are color-coded and much more useful IMHO. See 'em here: http://www.main.experiencetherave.com/suba...cans/FSM_Scans/ Best of luck with your project; be sure to post pics of your progress! My build-in-progress is chronicled at http://www.914world.com/bbs2/index.php?act...f=2&t=83031 Geoff |
Numbchux |
Nov 5 2009, 03:16 AM
if you happen to have a good wiring diagram for an ej22 NA 91-94 dual port exhaust that would be very helpful. just engine control stuff on the downloads page of my website: http://www.numbchuxconversions.com/downloads.htm most of the service manual: http://www.numbchuxconversions.com/Files/F...amp;_Wiring.pdf JJ914GT: the JDM stuff is kind of hard to find diagrams for. yours should be an EJ20K, which *should* mean this would include the right diagrams: http://www.numbchuxconversions.com/Files/F...ringdiagram.pdf otherwise, stuff for a later EJ20G: http://www.numbchuxconversions.com/Files/F...KWiringDiag.pdf hope that helps!! |
BIGKAT_83 |
Nov 5 2009, 07:34 AM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
if you happen to have a good wiring diagram for an ej22 NA 91-94 dual port exhaust that would be very helpful. just engine control stuff on the downloads page of my website: http://www.numbchuxconversions.com/downloads.htm most of the service manual: http://www.numbchuxconversions.com/Files/F...amp;_Wiring.pdf JJ914GT: the JDM stuff is kind of hard to find diagrams for. yours should be an EJ20K, which *should* mean this would include the right diagrams: http://www.numbchuxconversions.com/Files/F...ringdiagram.pdf otherwise, stuff for a later EJ20G: http://www.numbchuxconversions.com/Files/F...KWiringDiag.pdf hope that helps!! Numchux Great stuff on your website. Your EJ conversion manual has alot of info and anyone doing a conversion needs to read it. Thanks for all the work on this. Bob |
JJ914GT |
Nov 5 2009, 03:29 PM
pktzygt |
Nov 6 2009, 09:06 AM
Member Group: Members Posts: 328 Joined: 20-March 07 From: Chesapeake, VA Member No.: 7,611 Region Association: MidAtlantic Region |
Holy crap! I've been looking for that (in english) forever.
budman5201 |
Nov 6 2009, 12:45 PM
Senior Member Group: Members Posts: 595 Joined: 1-April 07 From: tempe, az Member No.: 7,635 |
GO with a Link Storm ECU and wiring is cake! Thats what i am using.
VOX |
Nov 6 2009, 04:54 PM
thanks alot! im sure it will come in handy.
Lo-Fi Version | Time is now: 12th May 2024 - 03:03 AM |
