Newbie Question of the Day:, Fuel Hoses |
RiqueMar |
Nov 5 2009, 11:05 AM
Enrique Allen Mar Group: Members Posts: 2,169 Joined: 28-August 08 From: San Diego, CA Member No.: 9,478 Region Association: Southern California |
Ok, so it's about that time to put the engine in, and I remembered that I need to replace the fuel lines. I've been looking at the ones on Pelican, but don't know what type I need 6,7, or 8 mm ID if I'm running carbs?
URY914 |
Nov 5 2009, 11:33 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,708 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
You'll need to measure the fitting on the carb to see what hose you'll need.
RiqueMar |
Nov 5 2009, 12:42 PM
underthetire |
Nov 5 2009, 02:32 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Well, sort of. If it's not to loose or to tight. I recommend the high pressure stuff even with carbs in CA. The "clean" fuel we have will break down std lines and send tiny debris in to your jets IMO. The high pressure stuff has a liner in it.
Lo-Fi Version | Time is now: 20th May 2024 - 09:21 AM |
