| mxhondarider832 |
Nov 5 2009, 01:45 PM
Newbie ![]() Group: Members Posts: 1 Joined: 5-November 09 From: carlsbad,CA Member No.: 11,013 Region Association: None |
I have a '74 914 and the transmission is a little leaky and need to change the fluid, the book says to use straight 90w oil but I am having a really tough time finding it so I was wondering if there was a newer substitute that I could use. This is my first 914 and I am struggling a little bit and could use some help thanks
| underthetire |
Nov 5 2009, 01:54 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
OH no, you just poked a pimple. I use 80/90 standard crap now. Had redline$$$ MTL in it once. Shifts better with the cheap stuff. A lot of guys use Sweepco and they will soon respond and tell you where to get it. I think it's up to you how much to spend on the oil.
| Zundfolge |
Nov 5 2009, 02:18 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 847 Joined: 12-August 07 From: Colorado Springs Member No.: 7,994 Region Association: Rocky Mountains |
I had a harder time finding the 17mm allen wrench locally than I did 90w.
| SirAndy |
Nov 5 2009, 02:19 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,488 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Swepco 201 is expensive and the Cap'n will tell you it's no good but i've been running it for years with very good results.
It made a noticeable improvement in shifting from whatever the PO had used. Transmission oil is not really a "wear" item, which makes it easier to justify the extra expense for Swepco. I cleaned up and re-sealed my 901 about two years ago and it's still bone dry. (IMG:style_emoticons/default/stirthepot.gif) Andy PS: (IMG:style_emoticons/default/welcome.png) |
| tat2dphreak |
Nov 5 2009, 02:54 PM
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
I'm using Valvoline 85w-90 I think it's a good oil at a good weight and that's what matters.
| Drums66 |
Nov 5 2009, 04:27 PM
914 Rudiments ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
QUOTE Had redline$$$ MTL in it once. That's what I use!........put whatever you want in it! as long as it's expensive! LOL (IMG:style_emoticons/default/stirthepot.gif)(that's what you say) |
| tod914 |
Nov 5 2009, 04:35 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
Just put the Swepco in mine. Shifts much better like Mr. Andy said. Need another spoon in that pot?
| Mark Henry |
Nov 5 2009, 04:51 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
Just use the cheap gear oil and change it once and awhile.
Swepco does have some pretty blue dye in it, so you can't miss it if you have a leak. |
| westgl |
Nov 7 2009, 12:50 AM
Newbie ![]() Group: Members Posts: 41 Joined: 14-November 08 From: Rogue River, OR Member No.: 9,756 Region Association: None |
Redline MTL is the old gearoil dont use it
USE: Redline MT90 it is Redlines latest, and works very well, much better than MTL. my 2cents Westgl |
| ME733 |
Nov 7 2009, 04:53 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 842 Joined: 25-June 08 From: Atlanta Ga. Member No.: 9,209 Region Association: South East States |
(IMG:style_emoticons/default/popcorn[1].gif) ...bottom line is THIS If you have really good sycronizers the expensive trick shit oils (silicone oils, or oils with ptf,s, etc,) will work better than std transmission oils..(for a while)..IF you have an older transmission with unknown sycronizers use good old VALVOLINE transmission oil found in qt bottles at your local auto parts store...80/w/90.....85/w/90. the gear oil as originally equiped was about a 90 wt oil...without any additives...... (IMG:style_emoticons/default/popcorn[1].gif)
| detoxcowboy |
Nov 7 2009, 04:58 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
make sure you get your fill plug off first before taking the drain plug off, that way if your fill plug is stripped stuck in there you won't be run dry with no way to fill it.. 80/90
| Dr Evil |
Nov 7 2009, 09:14 PM
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,044 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region
(IMG:style_emoticons/default/popcorn[1].gif) ...bottom line is THIS If you have really good sycronizers the expensive trick shit oils (silicone oils, or oils with ptf,s, etc,) will work better than std transmission oils..(for a while)..IF you have an older transmission with unknown sycronizers use good old VALVOLINE transmission oil found in qt bottles at your local auto parts store...80/w/90.....85/w/90. the gear oil as originally equiped was about a 90 wt oil...without any additives...... (IMG:style_emoticons/default/popcorn[1].gif) Um, no. Use 80w90 GL5 rated oil only. Redline oil is actually contraindicated in our gearboxes (hypoid gears). Here is something to consider for those of you who are slaves to the colored oils: The stock oil was 80w90 GL5 since 30 years ago. The stock oil lasted in abused and unabused gear boxes for 30 yrs. The colored oils have detergent properties that can be good or bad, depending. Detergents keep the dirt and crap that gets into your gear box emulsified so that instead of settling to the bottom and forming a nice sludge that I find 30yrs later, it creates a nice abrasive lubricant that causes things to wear faster. You might do well to put a filter over the vent on the case, but I dont know for sure. All I know is that nothing settles out of the colored oils and that aint natural. If you use the colored oils, change them often or suffer the abrasive consequences. |
| detoxcowboy |
Nov 7 2009, 10:18 PM
(IMG:style_emoticons/default/popcorn[1].gif) ...bottom line is THIS If you have really good sycronizers the expensive trick shit oils (silicone oils, or oils with ptf,s, etc,) will work better than std transmission oils..(for a while)..IF you have an older transmission with unknown sycronizers use good old VALVOLINE transmission oil found in qt bottles at your local auto parts store...80/w/90.....85/w/90. the gear oil as originally equiped was about a 90 wt oil...without any additives...... (IMG:style_emoticons/default/popcorn[1].gif) Um, no. Use 80w90 GL5 rated oil only. Redline oil is actually contraindicated in our gearboxes (hypoid gears). Here is something to consider for those of you who are slaves to the colored oils: The stock oil was 80w90 GL5 since 30 years ago. The stock oil lasted in abused and unabused gear boxes for 30 yrs. The colored oils have detergent properties that can be good or bad, depending. Detergents keep the dirt and crap that gets into your gear box emulsified so that instead of settling to the bottom and forming a nice sludge that I find 30yrs later, it creates a nice abrasive lubricant that causes things to wear faster. You might do well to put a filter over the vent on the case, but I dont know for sure. All I know is that nothing settles out of the colored oils and that aint natural. If you use the colored oils, change them often or suffer the abrasive consequences. Listen to the DR. he is the 914 transmission Dr. 80/90 GL5 |
| Drums66 |
Nov 8 2009, 01:37 PM
Redline MTL is the old gearoil dont use it USE: Redline MT90 it is Redlines latest, and works very well, much better than MTL. my 2cents Westgl Maybe??.......whatever type,it works for me(redline) and I've never had any issue's(20 years)our cars are 30 plus years old |
| Dr Evil |
Nov 8 2009, 01:48 PM
From the redline website found here:
http://www.redlineoil.com/content/files/te...Tech%20Info.pdf "GEAR AND SYNCHRONIZER WEAR PROTECTION Most manufacturers of manual transmissions and transaxles recommend an 80W or 90W GL-4 lubricant. GL-5 gears oils which are required in hypoid differentials are not used in most synchromesh transmissions because the chemicals used to provide the extreme pressure protection can be corrosive to synchronizers, which are commonly made of brass or bronze. Typically, the use of a GL-5 lubricant in a synchromesh transmission will shorten the synchronizer life by one half. The extreme pressure requirements of spur gears and helical gears found in transmissions are not nearly as great as found in rear-wheel drive differentials. A GL-4 lubricant provides adequate protection for most manual transmissions, unless a unique design consideration requires the extra protection of a GL-5." "DIRECTIONS FOR USE Red Line MTL may be used in transmissions which recommend 75W, 80W, or 85W GL-4 gear oils, or SAE 30 or 5W/10W30 motor oils. If a 90W GL-4 or SAE 40, 10W40, or 15W40 is required, MT-90 may be used. If the transmission or transaxle requires an SAE 90 GL-5 gear oil, then Red Line 75W90NS or 75W140NS Gear Oil may be used. In transmissions which recommend Dexron or Mercon fluids we recommend our D4 ATF which is very similar to the MTL, being a GL-4 Gear Oil also. The D4 ATF will provide better low-temperature shiftability, and the MTL would provide better wear protection for racing use. MTL is not designed for use in rear-wheel drive differentials. Those generally require a GL-5 lubricant such as Red Line 75W90 Gear Oil. It is not necessary to flush the transmission before replacing with MTL. Remove the drain plug and drain while warm. Seal compatibility has been designed to be similar to petroleum lubricants, and leakage should be no greater than any other oil of comparable viscosity. Being formulated with extremely stable synthetic basestocks, MTL and MT-90 will last much longer than conventional petroleum lubricants. However, we do not recommend extended drain intervals, since without a filtration system, there is no way to remove metal shavings other than draining the lubricant. The regular maintenance intervals are also recommended to insure that the proper level of the fluid is maintained." I have found before that they specifically prohibited use with hypoid gears, but I do not see that here in such plain speak. OUr boxes need GL-5, but they do not have brass or bronze synchros so the wear there is not of concern. We do have such yellow metals with in the gear box, though, and the GL-5 stuff can attack and oxidize the metals so that they are not pretty...but after 30+ years this has not become a failure point or even a perceived failure point. |
| Cap'n Krusty |
Nov 8 2009, 02:58 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
I don't recall EVER saying Swepco gear oil is bad, just that it's a waste of money. GL5 is the oil of choice, specified by the factory. What you MUST avoid is any "slippery" additives, as the synchronizers depend on FRICTION to work. Less friction, less effective synchros, more grinding, more dog teeth wear, more frequent (and more expensive) overhauls. As for Redline, I think the good Dr. has covered that very nicely. We have similar issues in Audi quattros. We use GL4 in the transaxles and GL5 in the rear diffs. Synthetic GL4 is specified, and it REALLY makes a difference in the life span of the tranny.
The Cap'n |
| astronomerdave |
Nov 9 2009, 01:11 AM
Member ![]() ![]() Group: Members Posts: 69 Joined: 26-January 09 From: Los Angeles, CA Member No.: 9,979 Region Association: Southern California |
So, the people selling components to convert 914s to electric are saying to use Royal Purple. In fact, if you buy an EV conversion kit, 4 qts of Royal Purple are included. Beats me. (IMG:style_emoticons/default/confused24.gif)
| Drums66 |
Nov 9 2009, 01:16 PM
Blah Blah Woof Woof..........I go by experience ,you can't believe
everything you read..... did you read my last post(20 years) same gear oil, people have mind's of their own...I do! (IMG:style_emoticons/default/finger.gif) Come with the Drama asshole's!! no more from me on this topic! |
| Dr Evil |
Nov 9 2009, 01:22 PM
(IMG:style_emoticons/default/WTF.gif) is your problem?
| astronomerdave |
Nov 9 2009, 01:32 PM
did you read my last post(20 years) same gear oil yep. just was adding what another group's opinion is. nothing more. hence the "beats me". (IMG:style_emoticons/default/huh.gif) |
Lo-Fi Version | Time is now: 25th July 2026 - 08:13 PM |
