koni or bilstein, help me decide |
vintage914racer |
Nov 8 2009, 10:10 AM
Member Group: Members Posts: 429 Joined: 28-December 03 From: Minneapolis, MN Member No.: 1,473 |
I need new rear shocks for the race car and plan on getting coilover sleeves. Why would one choose bilsteins over konis or vice versa. Car currently has konis that are shot...
I've searched past threads and I've seen people use both. I'm just curious why people choose one over the other. |
J P Stein |
Nov 8 2009, 10:26 AM
I prefer Bilsteins. They can be revalved for your usage by Bilstein for 65 bucks each.
Konis are adjustable....kinda. Shock dynos show a wild variation in adjustments on Konis.....both at "soft", "hard", & every where in between, whereas Bils show nearly equal. The Bils are a bit more expensive. Ya do your research, pays your money & takes your chances. |
vintage914racer |
Nov 8 2009, 02:02 PM
I prefer Bilsteins. They can be revalved for your usage by Bilstein for 65 bucks each. Konis are adjustable....kinda. Shock dynos show a wild variation in adjustments on Konis.....both at "soft", "hard", & every where in between, whereas Bils show nearly equal. The Bils are a bit more expensive. Ya do your research, pays your money & takes your chances. The bilsteins I should be looking at are bilstein sports, right? |
J P Stein |
Nov 8 2009, 03:20 PM
If you're gonna have them revalved, it doesn't matter. If not, I would guess yes.
BTW, I'm currently starting to set up my MR 2 Turbo for SCCA C Stock and was in the same quandry. Konis (recommended by some) or Bils (recomeneded by noone).....bout 300 bucks more for the Bils but the Bils are a whole new strut and the Konis are an insert. Looks like revalved Bils are gonna be the ticket.....but I've been wrong before.....sigh...... |
brilliantrot |
Nov 8 2009, 06:18 PM
Member Group: Members Posts: 125 Joined: 27-April 07 From: Costa Mesa Ca. Member No.: 7,699 |
Just went from new Koni Yellows to new Bilsteins Sports on the back of my dad's 911 and we like the Bilsteins better. FYI the Bilsteins have a lot more compression valving (raised the rear of the car .5") and I have been told have more rebound valving than the Konis on full stiff.
Joe Ricard |
Nov 9 2009, 11:24 AM
Either shock can be valved to what you need.
I say "NEED" because what you want is not always what you need. Bilstien is a better product. all the shocks race or street have the same common parts. |
J P Stein |
Nov 9 2009, 03:34 PM
Randal |
Nov 9 2009, 04:36 PM
So how do you go about getting a bilstein re-valved for your car. How do you come up with the values for the re-valve?
grantsfo |
Nov 9 2009, 05:00 PM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
So how do you go about getting a bilstein re-valved for your car. How do you come up with the values for the re-valve? Our 914 resident expert locally is Bill C. I sat in on session with him and professional shock guy at Infineon for his custom valved Koni's. They ran models based on wheel weights, spring rates, how much rebound, compression, etc. Pretty impressive stuff. Worth talking to Bill. |
Randal |
Nov 9 2009, 06:43 PM
So how do you go about getting a bilstein re-valved for your car. How do you come up with the values for the re-valve? Our 914 resident expert locally is Bill C. I sat in on session with him and professional shock guy at Infineon for his custom valved Koni's. They ran models based on wheel weights, spring rates, how much rebound, compression, etc. Pretty impressive stuff. Worth talking to Bill. Great, OK wheel weights spring rates rebound compression Question: etc, what specific things please |
grantsfo |
Nov 10 2009, 01:49 PM
So how do you go about getting a bilstein re-valved for your car. How do you come up with the values for the re-valve? Our 914 resident expert locally is Bill C. I sat in on session with him and professional shock guy at Infineon for his custom valved Koni's. They ran models based on wheel weights, spring rates, how much rebound, compression, etc. Pretty impressive stuff. Worth talking to Bill. Great, OK wheel weights spring rates rebound compression Question: etc, what specific things please You know me I'm terrible with technical stuff. In one ear out the other. When Tripoint did my custom Mazda coilovers with koni 030 tubes they asked all sorts of questions including what type of tire I was using. I just knew what kind of handling characteristics I wanted and spent lots of time explaining car use, tire setup etc. Best you talk to the experts at Performance Shock at Infineon. I forget the guy's name but he has a UK accent. They have all cool dyno and modeling equipment in the shop. Little hole in the wall shop with lots of cool suspension stuff. http://performanceshock.com/service-repair...rs-and-rebuilds This post has been edited by grantsfo: Nov 10 2009, 02:02 PM |
Lo-Fi Version | Time is now: 29th April 2024 - 09:43 PM |
