I want my MFI back!, I hate these overgrown purfume atomizers!!! |
ClayPerrine |
Nov 15 2009, 07:31 PM
Life's been good to me so far..... Group: Admin Posts: 15,474 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I got my 914/6 back up and running with the 2.4S conversion parts, including the MFI!! God, I LOVE the sound of MFI at full song! With the S cams it has the same scream a 917 has.
Friday morning I was running the car, tweaking some little things when the injection pump died. (IMG:style_emoticons/default/mad.gif) I only have one S pump, so I was forced to remove the MFI from my six. It will take 6 to 8 weeks to get the pump rebuilt, and I have to have a way to get to my new job on Monday. So, under duress, I installed my set of 40IDA3C Webers. (IMG:style_emoticons/default/barf.gif) I rejetted them to the settings mentioned on the Early S registry for a 73 2.4S motor. Main Jets #32 Venturis #135 Air Correction Jets #180 Idle Jets #60 Emulsion Tubes F3 Now I have to deal with all the carb crap.... like clogged idle jets, out of sync air bleed screws, UGH!!! Has anyone found a way to keep the idle jets from plugging up? I have been working on the car off and on since Friday, and have cleaned the idle jets 5 times. I still have to lower the accelerator pump stroke to lessen the black smoke under initial throttle opening. The car runs ok, but it doesn't run like the MFI does..... (IMG:style_emoticons/default/sad.gif) |
Nov 15 2009, 08:15 PM
Carbs suck. Fuel injection is sooo much gooder ... (IMG:style_emoticons/default/rolleyes.gif)
(IMG:style_emoticons/default/popcorn[1].gif) Andy |
GeorgeRud |
Nov 15 2009, 08:37 PM
Actually; carbs do suck, and fuel injection blows!
Set up correctly, either will do the job, but there is something magical about a well set up MFI system. I'm always in awe of the engineers that figured out those three dimensional space cams in the MFI pumps. Who are the good rebuilders of these pumps these days? There was a fellow in Rockford, IL, but he passed away a good number of years ago. |
ClayPerrine |
Nov 15 2009, 08:40 PM
Actually; carbs do suck, and fuel injection blows! Set up correctly, either will do the job, but there is something magical about a well set up MFI system. I'm always in awe of the engineers that figured out those three dimensional space cams in the MFI pumps. Who are the good rebuilders of these pumps these days? There was a fellow in Rockford, IL, but he passed away a good number of years ago. Gus at Pacific Fuel Injection....... |
number6 |
Nov 15 2009, 09:39 PM
Member Group: Members Posts: 352 Joined: 14-September 08 From: portland, or Member No.: 9,546 Region Association: Pacific Northwest |
jmill |
Nov 15 2009, 09:46 PM
Good fuel filters and air filters are the only way to keep them from plugging.
It's a little pricey for me but you can buy this NOS pump off ebay right now. It has a buy it now option with free shipping. (IMG:style_emoticons/default/happy11.gif) http://cgi.ebay.com/ebaymotors/Porsche-911...eQ5fCarQ5fParts |
ClayPerrine |
Nov 15 2009, 09:54 PM
Good fuel filters and air filters are the only way to keep them from plugging. It's a little pricey for me but you can buy this NOS pump off ebay right now. It has a buy it now option with free shipping. (IMG:style_emoticons/default/happy11.gif) http://cgi.ebay.com/ebaymotors/Porsche-911...eQ5fCarQ5fParts That is not the pump I need. That is a 964 pump, and it doesn't have all the stuff necessary to run it on the street. I have an 69 S pump, but it will have to be rebuilt. I have the K&N Watershield air cleaners. Any recommendation on fuel filters????? |
jmill |
Nov 15 2009, 10:08 PM
I figured that wasn't your pump. The $21k price tag would blow my budget.
I like the metal filters. If you stick with the major brands they usually have more folds giving you more filter area and they usually filter smaller particles. Attached File(s) filter.bmp ( 305.52k ) Number of downloads: 48 |
sixnotfour |
Nov 15 2009, 10:47 PM
914 Wizard Group: Members Posts: 10,433 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Dont you have a filter/cold start console with your mfi ? If you dont thats prob. what killed your pump.
best filter around Attached image(s) |
Eric_Shea |
QUOTE Any recommendation on fuel filters????? Factory for that engine. Just got my pump back from Robert at Jerry Fairchild Industries in Redding. It's where a lot of the other "tuners" send theirs and double his price upon returning it to you. |
Cap'n Krusty |
Nov 15 2009, 10:50 PM
K&Ns? There's your problem. The dirt particles they let through are easily the jet-clogging size. Get yourself a proper OE air cleaner and the correct pleated paper air filter. Less filter area, bigger pores = more air flow. More dirt, too. And more of that macho "look at me" noise, as well.
The Cap'n |
brp986s |
Nov 15 2009, 11:18 PM
Member Group: Members Posts: 434 Joined: 27-September 07 From: los angeles Member No.: 8,167 |
Idle jets get clogged from K&N's? Hmmmm
My theory was that to avoid clogged jets was to clean your tank. As you drive, the silt in your tank gets ground up into particles so fine that they go right thru the filter. But yeah, to me webers make better desk ornaments these days and motronic is too civilized for 914-6. Congrats on pulling off an mfi - I chickened out on that. |
lotus_65 |
Nov 16 2009, 05:03 AM
Senior Member Group: Members Posts: 1,608 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region |
Good fuel filters and air filters are the only way to keep them from plugging. It's a little pricey for me but you can buy this NOS pump off ebay right now. It has a buy it now option with free shipping. (IMG:style_emoticons/default/happy11.gif) http://cgi.ebay.com/ebaymotors/Porsche-911...eQ5fCarQ5fParts 21k? (IMG:style_emoticons/default/new_shocked.gif) i won't be playing in the that park! |
jmill |
Nov 16 2009, 11:31 AM
K&N's are meant to be cleaned and oiled. They have bigger holes for junk to get through than a paper element. Thats why you get a HP increase with K&N's. Less restriction to flow. The oil is supposed to catch the junk. It sometimes doesn't.
Nov 16 2009, 11:47 AM
bandjoey |
Nov 16 2009, 11:52 AM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Congratz on the new job. Now U can get that 450hp monster finished. (IMG:style_emoticons/default/beerchug.gif)
is there such a thing as MFI for 4cyl? |
zymurgist |
Nov 16 2009, 11:58 AM
"Ace" Mechanic Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
is there such a thing as MFI for 4cyl? I remember what happened last time somebody asked that question... (IMG:style_emoticons/default/wink.gif) |
Nov 16 2009, 12:00 PM
is there such a thing as MFI for 4cyl? I remember what happened last time somebody asked that question... (IMG:style_emoticons/default/wink.gif) He got clubbed like a baby seal? (IMG:style_emoticons/default/confused24.gif) |
number6 |
Nov 16 2009, 12:22 PM
zymurgist |
Nov 16 2009, 12:29 PM
is there such a thing as MFI for 4cyl? I remember what happened last time somebody asked that question... (IMG:style_emoticons/default/wink.gif) He got clubbed like a baby seal? (IMG:style_emoticons/default/confused24.gif) Yeah, pretty much. Although I thought that the original question was a valid question, asked in a respectful manner, and deserved an on-topic reply. |
Lo-Fi Version | Time is now: 22nd May 2024 - 10:07 AM |
