opinions on brake lines, steel braided teflon; stock rubber; 17-19-23mm MCs |
dlestep |
Nov 17 2009, 09:01 PM
I am smilin'... Group: Members Posts: 890 Joined: 15-January 08 From: Sunrise Florida Member No.: 8,573 Region Association: South East States |
...I guess I'll start off with my thinking...
My 73 started with a 17mm MC with stock brake lines. I was experiencing spongy brakes. After replacing all the lines and rebuilding the stock calipers and replacing all of the fluid and a proper bleeding. They felt inadequate during a spirited ride through the Cascades, when I lived there. I replaced the stock lines with steel braided teflon and changed the 17mm MC with a 19mm MC. The brakes improved, but the feel at the pedal was more compression was required (travel). I have read, more times than not, that the steel braided lines are breaking at the crimps and leaking causing brake failure. I ran them on my 73 with no problems from 1990 to 1997 until I scrapped it. I have been thinking of running stock lines. Have never heard nor read a problem with them... I am considering a 23mm MC, but I have two questions. Is there a length difference in the housing (mounting flange to body fwd end)? With the increase in volume, will the pedal travel increase over the 19mm MC? With the 19mm MC, when I entered a fast corner, I was able to simply roll my ankle over and blip the throttle as I down shifted while under breaking. The pedal travel would allow the brake pedal to be parallel (coplanar) with the throttle, at that position. When driving the 72 911, (with a 19mm MC), the brake travel under braking was less and the brake pedal position was above the throttle, forcing me to heel-toe, rather than the opposite as in the 73 914. Granted the 911 had M calipers, while the 73 914 had stock calipers. Now my 74 914 has Brembo AMs on the front and stock rears. I was thinking that the 23mm would be better suited to the Brembo AMs, or am I incorrect in my thinking.... ...all inputs are appreciated, Dave |
Lo-Fi Version | Time is now: 18th May 2024 - 01:02 AM |
