Secret on getting CV loose, What is it? |
damnfiknow |
Nov 17 2009, 09:15 PM
Member Group: Members Posts: 77 Joined: 25-October 09 From: Texas Member No.: 10,980 Region Association: None |
After using impact wrench to get the peskie bolts loose, I can't get the CV to turn loose of the wheel hub. "Gentle" tap on the ones at the transmission did the trick there. But can not get an good angle on the outboard ones. HELP
GeorgeRud |
Nov 17 2009, 09:23 PM
If it's an option for you, why don't you simply remove the large nut that holds the stub axle on and remove the entire assembly. You can then easily work on the halfshaft on the bench.
Just don't roll the car around with the stub axle removed, you'll probably ruin the bearing. |
mtndawg |
Nov 17 2009, 09:34 PM
Member Group: Members Posts: 414 Joined: 26-January 09 From: Granite Bay, Ca Member No.: 9,985 Region Association: None |
I just did this recently. It took an impact wrench to get the castle nut free. My half shaft was in tight and didn't want to tap through so I put the nut back on with a new cotter pin and called it good. The half shaft could press through with a gear puller and liquid wrench, but that could damage the wheel bearing. Long story short...if that outer boots are in good shape, don't worry about changing them. The inner boots are pretty easy.
detoxcowboy |
Nov 17 2009, 09:40 PM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
I had same exact issue, befuddled and gave up for the day, next day i just got int the best position I could on my back and yanked a couples times then rotated (the axel via the tire) an 1/8 turn and yanked more, just kept rotating and yanking just when I was done and felt I was a jerking fool... trying.... It yanked right off. Same thing other side just took alot of yanking and rotating, I am a novice and I got it in a long 40 minutes... "YANK & ROTATE" (IMG:style_emoticons/default/drunk.gif)
damnfiknow |
Nov 17 2009, 09:57 PM
I had same exact issue, befuddled and gave up for the day, next day i just got int the best position I could on my back and yanked a couples times then rotated (the axel via the tire) an 1/8 turn and yanked more, just kept rotating and yanking just when I was done and felt I was a jerking fool... trying.... It yanked right off. Same thing other side just took alot of yanking and rotating, I am a novice and I got it in a long 40 minutes... "YANK & ROTATE" (IMG:style_emoticons/default/drunk.gif) Looking at the book, it appears that the castellated nut is the only thing holding drive shaft in. I'm going to remove it and try a gentle tap. If it goes, I'll push it on through. If it is stuck I'll go for the "yank & rotate". I'm stuck with needing to get the shafts off as I want to flat tow the vehicle to a welding shop and then body shop before reinstalling the engine/transmission. Don't have this problem with the good old rear engined bay windows I have. |
detoxcowboy |
Nov 17 2009, 10:07 PM
I had same exact issue, befuddled and gave up for the day, next day i just got int the best position I could on my back and yanked a couples times then rotated (the axel via the tire) an 1/8 turn and yanked more, just kept rotating and yanking just when I was done and felt I was a jerking fool... trying.... It yanked right off. Same thing other side just took alot of yanking and rotating, I am a novice and I got it in a long 40 minutes... "YANK & ROTATE" (IMG:style_emoticons/default/drunk.gif) Looking at the book, it appears that the castellated nut is the only thing holding drive shaft in. I'm going to remove it and try a gentle tap. If it goes, I'll push it on through. If it is stuck I'll go for the "yank & rotate". I'm stuck with needing to get the shafts off as I want to flat tow the vehicle to a welding shop and then body shop before reinstalling the engine/transmission. Don't have this problem with the good old rear engined bay windows I have. good luck getting those nuts off (IMG:style_emoticons/default/blink.gif) I ha (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) e read (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) eads of guys using a 5 ft. fence pole for leverage (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) and still could'nt break them loose. Anyways I feel for you that was a frustrating morning but heart prevailed over lack of experience ...the 914 |
Spoke |
Nov 18 2009, 06:51 AM
Jerry Group: Members Posts: 6,985 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
If you tap the castle nut, put a piece of hardwood in between your hammer and the nut to spare the nut or threads from mushrooming.
The ideal way to get the outboard CV out is to remove the brake caliper and rotor and castle nut and put a gear puller on it. It should back right out. |
type47 |
Nov 18 2009, 07:24 AM
Probably, the 2 roll pins are holding the CV in. I would guess that the outer CV's are not removed as much and the pins "rust in" the flange and that's what's making it so hard to remove.
gklinger |
Nov 18 2009, 08:10 AM
doh! Group: Members Posts: 316 Joined: 14-January 03 From: Tempe, AZ Member No.: 146 Region Association: Southwest Region |
If you flat tow it with the stub axles out you will destroy the wheel bearings.
Lo-Fi Version | Time is now: 23rd May 2024 - 04:14 PM |
