> what oil pump would you use
wayne1234
post Nov 20 2009, 12:53 AM
Post #21
Well I'm going to order some parts today to put the engine back together, I basically have a stock 2.0 with a mild cam, and carbs, nothing special, should I just get a new factory oil pump or something else, I'M not gonna race it or any thing crazy, so Im thinking a stock setup would be fine where is the best place to get one? or am I crazy not to get "Blank set up" . Thanks and again recommend a vendor.
wayne1234   what oil pump would you use   Nov 20 2009, 12:53 AM
sww914   My experience with the aftermarket oil pumps is th...   Nov 20 2009, 01:03 AM
type47   I use the best used pump that I can scavenge out...   Nov 20 2009, 06:44 AM
jmill   There was a big thread about this. I believe that...   Nov 20 2009, 07:53 AM
tat2dphreak   I used a shadak 30mm pump. jake said the shadak...   Nov 20 2009, 08:11 AM
Mark Henry   Small engine so a shadak 26mm pump is all you need...   Nov 20 2009, 08:40 AM
wayne1234   how do you know if they are any good? someone said...   Nov 20 2009, 11:57 AM
ME733   :popcorn: I have used MELLING oil pumps with great...   Nov 20 2009, 04:55 PM
Drums66   :popcorn: I have used MELLING oil pumps with grea...   Nov 21 2009, 04:01 PM
Jake Raby   I'll post some pics of a Melling pump on Monda...   Nov 21 2009, 04:41 PM
StratPlayer   I'm running a melling in my new engine build. ...   Nov 22 2009, 03:14 PM
Cap'n Krusty   And, besides all those features, you get, free of ...   Nov 22 2009, 04:12 PM
Jake Raby   In testing now.. Available in both + and - .002 si...   Nov 22 2009, 06:12 PM
StratPlayer   The melling that I have on my engine has no leaks ...   Nov 22 2009, 07:50 PM
Jake Raby   The melling that I have on my engine has no leaks...   Nov 22 2009, 09:07 PM
Jake Raby   Here is your modern day Melling pump. This one...   Nov 23 2009, 09:33 AM
craig downs   I was using a Schadek oil pump and got scared of t...   Nov 24 2009, 12:56 AM
Jake Raby   Here is another...   Nov 24 2009, 09:16 AM
ME733   :popcorn: ....Very Intresting...I wonder what caus...   Nov 24 2009, 10:46 AM
StratPlayer   How many out there are running melling pumps and h...   Nov 24 2009, 10:52 AM
Drums66   How many out there are running melling pumps and ...   Nov 24 2009, 01:18 PM
jhadler   Have/had a Melling. Not sure if it's doing me ...   Nov 24 2009, 01:16 PM
Jake Raby   Like most everything else the quality of the Melli...   Nov 24 2009, 05:04 PM
jhadler   Perhaps my Melling is still in the "good...   Nov 24 2009, 05:08 PM
ME733   :popcorn: TO ..J Hadler , Craig Downs, and other...   Nov 25 2009, 06:27 AM
- Lo-Fi Version Time is now: 1st April 2026 - 09:32 PM
