Posts in this area are restricted to the following format. If you have a general question, please post it in the Garage.
1. All new threads MUST be titled with a part number only. (i.e. 901.351.801.17)
2. Thread description should be an english description of the part. (i.e. Brake Dust Shields)
3. Replies to the thread are only restricted by pertinence. Some examples are original finish of the part (painted, cad plated, etc), common failures (cracking at the mount points), repair information or tips, pictures (stock or custom), upgrades, etc.
If you have any questions regarding the rules of this forum, please PM McMark.
type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
PET illustration 201-10 #25 rubber sleeve
used for fuel lines through the engine shelf (near the battery) and for the brake fluid lines through body between brake fluid reservoir and master cylinder ![]() |
A&PGirl |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,019 Joined: 4-January 06 From: Oklahoma Member No.: 5,367 Region Association: None ![]() |
PET 201-10 #25 Qty: 1 (914/6) Qty: 2 (914/4)
PET 201-15 #5 Qty: 1 (914/4 1.8V) Qty: 2 (914/4 1.8/2.0) PET 604-00 #15 Qty: 2 New ![]() ![]() |
914Mike |
Member ![]() ![]() Group: Members Posts: 330 Joined: 27-January 03 From: San Jose, CA Member No.: 198 ![]() |
PET illustration 201-10 #25 rubber sleeve used for fuel lines through the engine shelf (near the battery) and for the brake fluid lines through body between brake fluid reservoir and master cylinder ![]() My '71 has those on the fuel lines under the tank as well. Later cars have the big rubber block with 2 holes for the fuel lines in that spot. |
Lo-Fi Version | Time is now: 11th July 2025 - 02:16 AM |
