oil leak! |
oil leak! |
dumbjim |
Dec 1 2009, 10:02 PM
Newbie Group: Members Posts: 25 Joined: 21-June 05 From: st.louis mo. Member No.: 4,312 |
I have a slight oil leak where the two halves of the crankcase come together. I know the correct way to fix it would be to split the case, but I would perfer to use a non correct, band aid, type solution. JB Weld, silicone caulk, duct tape. Any ideas guys?
RoadGlue |
Dec 1 2009, 11:28 PM
Sonoma County Gear Head Group: Admin Posts: 2,033 Joined: 8-January 03 From: Santa Rosa, CA Member No.: 108 Region Association: Northern California |
I'd just heat up the aluminum with a torch and fuse the two halves together. Ah huh. (IMG:style_emoticons/default/wink.gif)
Good luck! |
SGB |
Dec 2 2009, 07:59 AM
Welcome to the home of correct and non-correct solutions; the internet!
My solution to the same problem was a drip pan under the car... Seriously, there probably is not a band-aid for that. Randy's idea may be a little excessive... |
tat2dphreak |
Dec 2 2009, 09:28 AM
there is no band-aid... if it's not bad, then just deal with it until you can fix it proper
be sure that is where the oil is coming from, the oil can sometimes leak and run down to that seam, making it look like that's the leak... mine looked like that was the leak, but it was the galley plug. |
RoadGlue |
Dec 2 2009, 11:29 AM
Randy's idea may be a little excessive... I was joking, in case that wasn't completely obvious to everyone. (IMG:style_emoticons/default/smile.gif) |
Dec 2 2009, 12:51 PM
Resident German Group: Admin Posts: 41,649 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I'd just heat up the aluminum with a torch and fuse the two halves together. (IMG:style_emoticons/default/blowtorch.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 08:11 PM |
