Original Rear Defrost Harness'es? |
detoxcowboy |
Dec 3 2009, 09:53 AM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
Does anyone know of or have a picture of the Original Harness or Harnesses for the rear defrost windows? Did the 914 use 1 or all three? In the parts diagram is appears there is one harness from the switch and another from the relay board..
Part#'s OEM-91461205614 OEM-91461205610 OEM-91461205613 |
914Sixer |
Dec 4 2009, 02:16 PM
914 Guru Group: Members Posts: 8,882 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Different number for different years. 914-6 had the rear window harness built in, the stock 914 did not on early cars. PET will tell you what harness go with what years.
914werke |
Jan 11 2010, 01:03 AM
"I got blisters on me fingers" Group: Members Posts: 10,058 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Not sure about the /6 but there are two that I have encountered.
73-74 & 75-76. The Early runs from switch under dash thru the tunnel & firewall sleeve to connect with the relay board in the Eng. compartment. The late is is a shorter version that connects to the relay junction under the Pass seat. |
Cairo94507 |
Mar 3 2010, 07:50 AM
Michael Group: Members Posts: 9,750 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
So does that mean all 914-6's came with the rear defrost harness built in despite not coming with a rear defrost window? Thanks.
914Sixer |
Mar 5 2010, 08:10 AM
All the 70-71 harness I have seen have them built in. I can not say about the 72 model. As I understand it the 72 was mostly 914-4 with -6 adapter harnesses BUT I have never seen one in person.
Cairo94507 |
Mar 5 2010, 08:23 AM
OK, thanks. I appreciate your response.
Jasfsmith |
Mar 5 2010, 08:49 AM
Senior Member Group: Members Posts: 556 Joined: 4-October 04 From: Bangor, ME Member No.: 2,882 Region Association: North East States |
Can you recall where the lead comes out of the harness at the dash end?
914Sixer |
Mar 6 2010, 06:19 AM
Harness comes out by the lighter.
Cairo94507 |
Mar 6 2010, 06:57 PM
right between the lighter and the defroster/ventilation/heater controls. On my car I can feel the hole behind the basket weave material for the switch.
Lo-Fi Version | Time is now: 14th May 2024 - 11:57 AM |
