904 mainshafts, Anyone interested in repros? |
Dr Evil |
Dec 3 2009, 08:41 PM
Send me your transmission! Group: Members Posts: 23,001 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
I am checking interest in repro 904 main shafts. I think I can get them either made or made out of 901 shafts for much less than the $1800-2000 that they are commanding now.
Phoenix-MN |
Dec 3 2009, 08:47 PM
Senior Member Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 |
If the price was right, yes. I would probably do 2
Paul |
iamchappy |
Dec 3 2009, 08:48 PM
You might want to find out if this guy still has a connection. This is an old thread but he may save you some trouble if more can still be made.
http://forums.pelicanparts.com/porsche-911...here-950-a.html |
Dec 3 2009, 09:55 PM
Custom Member Group: Members Posts: 24,584 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Ottos Venice made a run of them and lowered the price due to flooding the market.
Carquip also has them, but I think he may have done a deal with Otto at the time...I forget how it went down. Not sure how many he has left right now. Rich |
FourBlades |
Dec 3 2009, 10:07 PM
From Wreck to Rockin Group: Members Posts: 2,054 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States |
What is the advantage of 904 main shafts? John |
McMark |
Dec 3 2009, 10:28 PM
Interchangeable second gear.
ottox914 |
Dec 3 2009, 10:31 PM
The glory that once was. Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
What is the advantage of 904 main shafts? John On a "stock" 901 main shaft, 2nd gear is fixed, as it is a part of the shaft, so if you want any custom gearing, you have to work around the stock ratio for 2nd gear. You can swap gear ratios for 1, 3, 4, 5, but not 2nd. A 904 main shaft allows you to pick any 5 ratios for your gear box, as all 5 gears can be swapped for any ratios you'd like. |
ChrisFoley |
Dec 4 2009, 05:51 AM
I am Tangerine Racing Group: Members Posts: 7,933 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
If you just want a taller second gear but won't need to change it again and again, its far cheaper to have a stock 901 mainshaft modified by welding on a third gear in place of 2nd, such as the "I" ratio.
I've done this several times. In fact, the way I do it - I could easily cut off the stock second and build up splines for interchangeable second gears just like the 904 - far cheaper than buying a new mainshaft. |
Dr Evil |
Dec 7 2009, 11:40 PM
Its looking like the cost will be far less than the one offered on PP. What does it cost through you, Chris? No sense in reinventing the shaft if youa re doing it for a low price. (IMG:style_emoticons/default/wink.gif)
ChrisFoley |
Dec 8 2009, 02:50 AM
Since I've always welded the new gear on I have to double check the method of securing an interchangeable gear in the proper location, but I'm pretty sure I can mod a stock mainshaft to accept any 3rd (4th, 5th) gear in the 2nd location for $400.
I've already been planning to take a couple of the mainshafts I have laying around and do this so I can stock them instead of only doing it to order. |
Dr Evil |
Dec 8 2009, 12:00 PM
Nice! The only thing is that the swapable 2nd gears are internally splined differently than 3-5. If using 3-5 gears in 2nd gear, one's 2nd gear would be pretty colossal compared to stock F, GA, or H. I may not be understanding something with what you are doing.
stownsen914 |
Dec 8 2009, 01:23 PM
Senior Member Group: Members Posts: 913 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
There are certain ratios from 4 speed 901s, like HB and I, that are 2nd gear ratios, but sit in the the third gear position in a 5 speed. Remember that 1st in a 901 4 speed is the fixed mainshaft gear, so a HB or I second gear from a 4 speed has the larger splines. The 4 speed versions of these gearsets may also be easier and cheaper to get than real 904 gearsets. I like Chris's idea (IMG:style_emoticons/default/smile.gif)
Scott |
brant |
Dec 8 2009, 01:28 PM
914 Wizard Group: Members Posts: 11,626 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Chris,
at $400-ish, I'm interested in buying a main shaft from you I could provide a core if needed. I don't have the money today, but will get it and would love to know availability when you get things figured out I'm running a 3rd gear moved to 2nd shaft currently. Mine is splined by making it out of a stock F-mainshaft exactly as your proposing. The current train of thought is that this mod is good for 200hp to the rear wheels in racing conditions. Its been done this way in colorado for approximately 10 years and held up to testing at 200hp I'm currently running a 2nd gear of "J" with this mod let me know if you make up some shafts in this manner brant |
davep |
Dec 8 2009, 03:36 PM
914 Historian Group: Benefactors Posts: 5,148 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
I recall some posts on Pelican written by Grady Clay saying that the 904 2nd gear ratios on a 904 shaft were a little weak, and he preferred machining and welding like Chris does. I have an A mainshaft that I was looking to have modified, and may find a few more.
Would welding be cheaper than splining? |
J P Stein |
Dec 8 2009, 03:44 PM
Best get your parts before you start. The gears ratios mentioned are scarce as hens
teeth and are priced accordingly. I've been watching for them for years and have found none used...new are made to order$$$. I finally went to the F mainshaft for first gear. You need a motor to pull it It does get rid of the cantilevered 1st, tho. |
brant |
Dec 8 2009, 06:02 PM
Best get your parts before you start. The gears ratios mentioned are scarce as hens teeth and are priced accordingly. I've been watching for them for years and have found none used...new are made to order$$$. I finally went to the F mainshaft for first gear. You need a motor to pull it It does get rid of the cantilevered 1st, tho. JP, you need to step into the world of rolling starts. then less motor is a requirement to use "F" as your first gear! JP has heard me say this a thousand times... but all kinds of things are possible I'm currently running F/J/S/O/V 5 useable gears to fit the needs of any track without changing the box as long as you avoid standing starts its perfectly fine... granted I'm shooting for 205hp to the wheels and will need to follow the 200hp rule also, but with a measley 2 liter that won't be a problem |
ChrisFoley |
Dec 8 2009, 07:28 PM
Would welding be cheaper than splining? Welding is cheaper than splining, however... In my opinion, simply welding the gear in place isn't adequate to resist the applied torque with the ratios used in this gear position. I create 4 of the 8 splines on the shafts I weld a gear on. In order to make the gear removable four more splines need to be built up and ground, as well as machining of the shoulder that the gear presses against. All the spline grinding is done by hand. I may have underestimated a little at $400 but I don't think its far off. Welding a gear is about $300. I'm still not 100% on the way the gear will be held in place. The intermediate plate bearing outer race will be taking the loads in one direction and its OD doesn't overlap the 3rd gear spline by much. If I was doing this with 904 2nd gears it would be no problem since, as the Dr mentioned, the splines are smaller in diameter. I would need a gear in hand to do it this way though. |
Dec 8 2009, 08:02 PM
Would welding be cheaper than splining? Welding is cheaper than splining, however... In my opinion, simply welding the gear in place isn't adequate to resist the applied torque with the ratios used in this gear position. I create 4 of the 8 splines on the shafts I weld a gear on. In order to make the gear removable four more splines need to be built up and ground, as well as machining of the shoulder that the gear presses against. All the spline grinding is done by hand. I may have underestimated a little at $400 but I don't think its far off. Welding a gear is about $300. I'm still not 100% on the way the gear will be held in place. The intermediate plate bearing outer race will be taking the loads in one direction and its OD doesn't overlap the 3rd gear spline by much. If I was doing this with 904 2nd gears it would be no problem since, as the Dr mentioned, the splines are smaller in diameter. I would need a gear in hand to do it this way though. Chris, I know the senior manager at Insco in Groton MA. A good friend. I would be happy to put you in touch. They have the equipment to do the shafts and gears....thats all they do. Rich |
ChrisFoley |
Dec 12 2009, 09:23 AM
Rich,
I don't think a gear specialty machine shop is necessary. All I need is a good precision machinist to do the preliminary cut to establish the minor diameter, and a final cut for the shoulder. The shop I've used locally for the previous shafts I've modded is perfect for this. In fact I will be seeing them soon for a little ski shooting. (IMG:style_emoticons/default/smile.gif) Maybe I should plan on bringing them several mainshafts to get the ball rolling. Dave P, I read Grady's article before I started my first shaft mod and decided to go one better by building up half of the splines before welding the gear in place. I think this method should handle more than the 200hp limit Brant mentioned. |
jd74914 |
Dec 12 2009, 11:03 AM
Edit: Hijack removed, Will send PM. (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 25th May 2024 - 03:18 AM |
