> Question: If I dented Condensor housing... is it bad? What's insi
x98boardwell
post Dec 6 2009, 08:58 AM
While I was putting the new condensor in my distributor I realized the green wire was just shorter than the stock unit I was taking out. I had to bend the flange on the condensor so that it would sit better on the distributor. When I did this I accidentally pushed in the metal a little bit on the condensor.
Will this ruin the condensor? Is anythign spinning inside? It may have been dented in 1mm or so at the most. I can take a picture if needed.
Thanks in advance for the help.
Bryan
- Lo-Fi Version Time is now: 1st July 2025 - 05:08 AM
