jmill |
Green Hornet ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest ![]() |
While you might be tempted to spend all your money at a machine shop, have some confidence and drill the two holes, put in the time certs and call it a day. Rich I agree. I've done exactly this with a TI case and a drill press. I've even done it with TI heads on the plug threads. After I drilled the hole I swapped out the drill bit for a tap. I tapped the hole by spinning the chuck by hand with just a little down pressure. That way I knew it was threaded straight. |
Cevan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 ![]() |
Is a thread locker required when reinstalling the head studs? Also, it looks like the 30mm timeserts are the right size. It's the longest size they make. 12Mx1.5 right?
underthetire |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California ![]() |
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,754 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() ![]() |
Before you go and spend $100 on the TimeCert kit... Consider this.
I had a local machinist install a time cert for $25. Now, granted, if you have to install 6 or 7 of them, its cheaper to do it yourself. But if you only need one done, its cheaper to have it done for you. Zach |
Cevan |
Before you go and spend $100 on the TimeCert kit... Consider this. I had a local machinist install a time cert for $25. Now, granted, if you have to install 6 or 7 of them, its cheaper to do it yourself. But if you only need one done, its cheaper to have it done for you. Zach I must live in a strange part of the country because there are probably 100 machine shops and the first 10 I called knew nothing about time serts. Hmmmm. |
underthetire |
Before you go and spend $100 on the TimeCert kit... Consider this. I had a local machinist install a time cert for $25. Now, granted, if you have to install 6 or 7 of them, its cheaper to do it yourself. But if you only need one done, its cheaper to have it done for you. Zach I must live in a strange part of the country because there are probably 100 machine shops and the first 10 I called knew nothing about time serts. Hmmmm. They have different names. Same animal. Automotive machine shops may not know, precision machine shops all will. Two different animals. With the ones I listed earlier, no special tools are required to install them, just a drill, a tap, and a screwdriver. Notice that the metric I.D. ones with a metric OD one is more than the metric ID / SAE OD. The tap for the SAE will be cheaper to. Still gives you the metric threads for your studs. |
Cevan |
I'm getting a headache. (IMG:style_emoticons/default/biggrin.gif)
I think I'll just start with a new case. |
ME733 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 842 Joined: 25-June 08 From: Atlanta Ga. Member No.: 9,209 Region Association: South East States ![]() |
(IMG:style_emoticons/default/popcorn[1].gif) Just out of curosity, why did you remove a head stud. ?. and if you have a choise, and a spare case, (which you do) I agree that you should use it. Inspect it carefully. (IMG:style_emoticons/default/popcorn[1].gif) Murray
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Brockton, Dedham and Newburyport.
There are others, but those are THE ones that get used the most up here. Collect all your projects and bring it all at once to a shop. Its one trip for all the parts. Rich |
Lo-Fi Version | Time is now: 4th July 2025 - 04:54 AM |
