Rear sway bar question?, What does the bushings go on first? The drop link or the sway bar? |
wallys914 |
Jan 6 2010, 12:07 AM
In life you don't get what you want, you get what you negoia Group: Members Posts: 190 Joined: 10-October 08 From: Garden Grove, Member No.: 9,631 Region Association: Southern California |
I got the bushings into the drop links but then when I attempted to put them on the sway bar they won't fit.
Any ideas or suggestions? |
Jan 6 2010, 03:40 PM
914 Idiot Group: Members Posts: 14,984 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
You're doing it right. In the drop-links first, onto the bar and ball stud next. It evidently helps to drill a small hole through the back side of the bushing to let the air out, but you'll still probably use a clamp to squeeze the drop-link onto the bar or ball-stud anyway.
I've done it without drilling the hole, but it's a pain. If I tried drilling the holes, I would probably goop a little RTV on to cover the holes once I was done, just to discourage dirt from entering. --DD |
Jan 6 2010, 03:45 PM
Resident German Group: Admin Posts: 41,635 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Huge C-Clamp and tiny hole on the backside of the bushing, lots-o-grease and they'll go on fairly easy ...
(IMG:style_emoticons/default/smash.gif) Andy |
Lo-Fi Version | Time is now: 13th May 2024 - 03:02 PM |
