I cleaned out my LE project yesterday..., and I found some interesting repairs |
dlee6204 |
Jan 7 2010, 07:43 AM
So yesterday I pulled my LE project out and started to clean it up a bit (remove spare parts, vacuum a bunch of crap out of it, etc) and I found quite a few trademarks of the previous owner.
WARNING: Sarcasm included I was cleaning out the rear trunk and I found a jagged hole. It appears they let a small bear change the starter at some point. |
dlee6204 |
Jan 7 2010, 07:49 AM
dlee6204 |
Jan 7 2010, 07:52 AM
dlee6204 |
Jan 7 2010, 07:59 AM
dlee6204 |
Jan 7 2010, 08:03 AM
914Sixer |
Jan 7 2010, 08:07 AM
Southern Engineering ??
dlee6204 |
Jan 7 2010, 08:53 AM
dlee6204 |
Jan 7 2010, 08:55 AM
dlee6204 |
Jan 7 2010, 08:59 AM
dlee6204 |
Jan 7 2010, 09:03 AM
dlee6204 |
Jan 7 2010, 09:09 AM
This next repair was actually pretty innovative. The accelerator cable broke so they used a nail to fix it. That's southern Engineering for ya.
I wonder if its real gold... (IMG:style_emoticons/default/poke.gif) |
dlee6204 |
Jan 7 2010, 09:12 AM
And last but not least this is my favorite! Classy... (IMG:style_emoticons/default/thumb3d.gif)
I've seen plenty of stupid things before but this is just tragic. Luckily the car will eventually get a full restoration and be repaired back to the way it should be. (IMG:style_emoticons/default/smash.gif) |
Smitty911 |
Jan 7 2010, 09:14 AM
Member Group: Members Posts: 294 Joined: 19-March 08 From: La Mirada, Ca Member No.: 8,830 Region Association: Southern California |
Another reason PIMPs should not own Porshce, any kind of Porsche.
At least it will get the love it deserves now. |
914werke |
Jan 7 2010, 09:22 AM
"I got blisters on me fingers" Group: Members Posts: 10,058 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
WOW!
IronHillRestorations |
Jan 7 2010, 09:27 AM
I. I. R. C. Group: Members Posts: 6,717 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Was that the car from Camden TN?
dlee6204 |
Jan 7 2010, 09:41 AM
VaccaRabite |
Jan 7 2010, 11:38 AM
En Garde! Group: Admin Posts: 13,443 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I'm still trying to figure out why they would put a 4-prong trailer connection in-line of what appears to be the fuel sender. Actually.... Thats not a half bad idea. It allows you to pull the gas tank without taking it apart first to unhook the wiring. The way they have the sender wired from the factory is kinda retarded. On my car, they just cut the wire and then taped it back together... (IMG:style_emoticons/default/sad.gif) At least your DAPO was better then mine in that respect. The nail to the go-pedal cable is a classic "it'l get ya home" fix. Course, then they forgot to fix the fix. Zach |
biosurfer1 |
Jan 7 2010, 11:58 AM
Teener fo Life! Group: Members Posts: 3,020 Joined: 3-August 03 From: Roseville, CA Member No.: 977 Region Association: Northern California |
That nail fix is classic...maybe Jake is wasting his time developing the cable system:)
McMark |
Jan 7 2010, 12:04 PM
QUOTE They used some odd-shaped steel dohickeys to shim the rear trailing arm. Actually, those are shims. Just not the correct ones for a 914. |
dlee6204 |
Jan 7 2010, 12:32 PM
QUOTE Actually.... Thats not a half bad idea. It allows you to pull the gas tank without taking it apart first to unhook the wiring. The way they have the sender wired from the factory is kinda retarded. Hm, interesting. That would explain why its there but a trailer connection is certainly not the answer. Everything on this car was half done whether it was a repair or a modification. Gotta love DAPOs. (IMG:style_emoticons/default/slap.gif) |
Lo-Fi Version | Time is now: 14th May 2024 - 05:33 PM |
