Subaru Transmission into 914, DAMN that turned out good!! |
DBCooper |
Jan 12 2010, 06:31 PM
14's in the 13's with ATTITUDE Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California |
Some photos of my 914 being fitted with a WRX transmission. I'm sorry, we replaced bushings, adjusted and aligned three times and that 901 never even got close to being acceptable. The WRX motor was such a huge improvement over the VW that it only seemed logical to make the transmission just as modern. And "while we're in there" the air-to-air intercooler is being replaced by a water to air. You just don't get the air flow in the back of the car you'd want to make big power, and the next step with this car will be an STI motor. Power is addictive. Yes, I know better and you've been warned.
Anyway, the WRX five speed with Quaife gets introduced to engine. (IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1268145993.1.jpg) The forest of jackstands as positioning is worked out. (IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1268145994.2.jpg) The WRX transmission axle outlets are a little closer to the flywheel than the 901, which meant the engine had to be moved back to keep the axles aligned with the stubs. (IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1268145995.3.jpg) Flipped manifold. Enough space in there now for an EZ30 six, easy. Nice looking hellhole too, don't you think? Still needs detailing of course, but first things first. (IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1268145995.4.jpg) But moving the engine back meant he had to box a small part of the rear trunk. That's OK, this car isn't for hauling luggage anyway. Or lawn tools. Or groceries. (IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1268145996.5.jpg) Cable shifter at the transmission. Beautiful work. (IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1268145997.6.jpg) And inside the car, the modified MR2 shifter. Feels notchy, accurate, and good, which is what this is all about. That and more strength, especially in first. (IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1268145998.7.jpg) A video of the shifter, still in the prototype stage, showing the action in the front and the rear. https://www.youtube.com/watch?v=ncmaxYd1WNI Ask Abby what she thinks of Grandpa's car. She likes to show off those pretty new teeth. (IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1268145998.8.jpg) The water-air intercooler. It will go just ahead of the engine on the driver's side. (IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1268145999.9.jpg) In the car, you can see part of the new cradle, just tacked for the moment. (IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1268146000.10.jpg) Axles are aligned. (IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1268146001.11.jpg) Business end, seen from the rear. It looks so good we'll probably go without a valence, it's gotta be seen. I can't wait until in the rearview mirror I see another 914 guy who's pulled up behind and is trying to figure out what all happened back there. (IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1268146001.12.jpg) This work is being done by a wizard at a shop called 40-Thirteen in Modesto, CA. Quality of work is unmatched. If you're curious there are a lot more pictures of this transmission project, the engine cradle, what the car looked like with just the WRX motor before these changes, or more pictures of that beautiful granddaughter in an album at: http://photobucket.com/Corinthiano More to come later. It was a monster before, but you had to be real gentlemanly with the shifter. To hell with that. I can't wait. . |
DBCooper |
Mar 25 2010, 05:52 PM
As part of their destructive testing program the kids took the car to a PCA autocross in Stockton.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i255.photobucket.com-2618-1269561145.1.jpg) Good news is that they didn't break anything. Bad news is that we're back at square one for suspension setup. They say the front end pushes badly at low speeds, and, surprise surprise, the back end goes liquid under power. Their suggestion is flares and big stickies, but that isn't going to happen. All I want is a narrow-body sleeper. So it looks like bigger 7 inch wheels on the front (it's now 6's and 7's) and learning how to drive it differently, moderating the power a little better. Then we'll tweak as we go along. All in all it's great, a total success and a helluva lot of fun to drive. |
strawman |
Mar 26 2010, 11:13 PM
Senior Member Group: Members Posts: 881 Joined: 25-January 08 From: Los Osos, CA Member No.: 8,624 Region Association: Central California |
They say the front end pushes badly at low speeds, and, surprise surprise, the back end goes liquid under power. This car has a Quaife limited slip dif, eh? I wonder if the limited slip and power-on while entering the turn and/or during decel is the cause of understeer. Could this be resolved by changing the driving style a bit? I am very interested in this issue, as I've installed an OBX LSD in my Suby trans... |
DBCooper |
Mar 27 2010, 06:08 AM
They say the front end pushes badly at low speeds, and, surprise surprise, the back end goes liquid under power. This car has a Quaife limited slip dif, eh? I wonder if the limited slip and power-on while entering the turn and/or during decel is the cause of understeer. Could this be resolved by changing the driving style a bit? I am very interested in this issue, as I've installed an OBX LSD in my Suby trans... That's the likely explanation. I had some of the push before and I'd already gotten those 7 inch wheels as part of the cure. We'll see what that does and go from there, but the message after the autocross was that we're going to need to learn to drive the car differently and especially use the accelerator more in steering. It's not a big deal, it was the first time out to see where we were, a shake down and learning experience. The engine and transmission are in and good, so from now on it's going to be fun sorting the new car out. I'm not nearly as interested in how it does at autocrossing as I am how it does in the hills, but autocrossing is perfect for the sorting and learning how to drive it without ending up in the weeds. . |
Lo-Fi Version | Time is now: 15th May 2024 - 09:35 PM |
