Subaru Transmission into 914, DAMN that turned out good!! |
DBCooper |
Jan 12 2010, 06:31 PM
14's in the 13's with ATTITUDE Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California |
Some photos of my 914 being fitted with a WRX transmission. I'm sorry, we replaced bushings, adjusted and aligned three times and that 901 never even got close to being acceptable. The WRX motor was such a huge improvement over the VW that it only seemed logical to make the transmission just as modern. And "while we're in there" the air-to-air intercooler is being replaced by a water to air. You just don't get the air flow in the back of the car you'd want to make big power, and the next step with this car will be an STI motor. Power is addictive. Yes, I know better and you've been warned.
Anyway, the WRX five speed with Quaife gets introduced to engine. (IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1268145993.1.jpg) The forest of jackstands as positioning is worked out. (IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1268145994.2.jpg) The WRX transmission axle outlets are a little closer to the flywheel than the 901, which meant the engine had to be moved back to keep the axles aligned with the stubs. (IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1268145995.3.jpg) Flipped manifold. Enough space in there now for an EZ30 six, easy. Nice looking hellhole too, don't you think? Still needs detailing of course, but first things first. (IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1268145995.4.jpg) But moving the engine back meant he had to box a small part of the rear trunk. That's OK, this car isn't for hauling luggage anyway. Or lawn tools. Or groceries. (IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1268145996.5.jpg) Cable shifter at the transmission. Beautiful work. (IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1268145997.6.jpg) And inside the car, the modified MR2 shifter. Feels notchy, accurate, and good, which is what this is all about. That and more strength, especially in first. (IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1268145998.7.jpg) A video of the shifter, still in the prototype stage, showing the action in the front and the rear. https://www.youtube.com/watch?v=ncmaxYd1WNI Ask Abby what she thinks of Grandpa's car. She likes to show off those pretty new teeth. (IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1268145998.8.jpg) The water-air intercooler. It will go just ahead of the engine on the driver's side. (IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1268145999.9.jpg) In the car, you can see part of the new cradle, just tacked for the moment. (IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1268146000.10.jpg) Axles are aligned. (IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1268146001.11.jpg) Business end, seen from the rear. It looks so good we'll probably go without a valence, it's gotta be seen. I can't wait until in the rearview mirror I see another 914 guy who's pulled up behind and is trying to figure out what all happened back there. (IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1268146001.12.jpg) This work is being done by a wizard at a shop called 40-Thirteen in Modesto, CA. Quality of work is unmatched. If you're curious there are a lot more pictures of this transmission project, the engine cradle, what the car looked like with just the WRX motor before these changes, or more pictures of that beautiful granddaughter in an album at: http://photobucket.com/Corinthiano More to come later. It was a monster before, but you had to be real gentlemanly with the shifter. To hell with that. I can't wait. . |
76-914 |
Aug 2 2015, 03:36 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,502 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Same thing on the shifter. My son has the same MR2 shifter and cables, but his uses the linkage with the bell crank. My cable that rotates the shaft is longer and curves around for a direct shot at that bracket, so there's no bell crank, nothing mechanical in the linkage. In a direct comparison between the two, mine shifts lots nicer than his, both light years better than stock. In fairness we chose all all off-the-shelf components so we could convert his 901 to the Subaru transmission in one weekend, to get it done before his HOA even noticed. I say we, but he actually did all the work. I'm old so I supervise. IIRC, I somewhat copied your holder because of 1 reason Paul. No moving parts. KISS. It is still as smooth as day 1. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 16th May 2024 - 02:37 AM |
