charliew |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 ![]() |
Mike I'm sure you have also thought about the other 901 guys that will also be interested in this project. Thats where my first experience with this tranny came from. I actually bought 914 tranny's because they were cheap parts donors for the 911/901 before I got a complete 914 for a donor hotrod. Don't forget samba either.
Katmanken |
You haven't seen me if anybody asks... ![]() ![]() ![]() ![]() Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest ![]() |
Evil,
Hows about a little dialoge on dos and don'ts and an explanation "Do not not synthetic oil. The 901 uses friction bands in the synchros, and the change in friction can cause shifting problems " "Don't dissasemble multiple gear boxes and mix all the parts. Gear stacks were measured at the factory and pre-assembled with a correct shim stack for the tolerance stackup. Mix the parts up without careful measurement and you mess up the tolerance stackup and that can change factories measured ring and pinion mesh. That can lead to to premature wear, gear whine etc.... If you do swap gears between different boxes, do it only as matched pairs. The gears are used to running together (ie worn together) and should remain matched. (One from the drive shaft and one from the driven shaft) Do swap dog teeth and friction bands around. They do not interfere in the shaft stackup and can be swapped around between locations in a gearbox and between different transmisions. Go with the best parts. And, hows about a little dialogue on replacing bearings in the intermediate bearing plate and/or the angled bearings in the differential. I owe you a picture of a tool. I found a punch that is perfect for removing the roll pin from the small first gear castellated nut. Ken |
RoadGlue |
Sonoma County Gear Head ![]() ![]() ![]() ![]() Group: Admin Posts: 2,033 Joined: 8-January 03 From: Santa Rosa, CA Member No.: 108 Region Association: Northern California ![]() ![]() |
Hey Mike, this is awesome! Let me know if I can help in anyway.
Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,096 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
Special tool list please. Reasonable substitutes for special tools. (IMG:style_emoticons/default/idea.gif) |
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
Mike I'm sure you have also thought about the other 901 guys that will also be interested in this project. Thats where my first experience with this tranny came from. I actually bought 914 tranny's because they were cheap parts donors for the 911/901 before I got a complete 914 for a donor hotrod. Don't forget samba either. The tail shifter is analogous to the 911/901 and will be addressed in the video (IMG:style_emoticons/default/smile.gif) |
Dr Evil |
Evil, Hows about a little dialoge on dos and don'ts and an explanation "Do not not synthetic oil. The 901 uses friction bands in the synchros, and the change in friction can cause shifting problems " "Don't dissasemble multiple gear boxes and mix all the parts. Gear stacks were measured at the factory and pre-assembled with a correct shim stack for the tolerance stackup. Mix the parts up without careful measurement and you mess up the tolerance stackup and that can change factories measured ring and pinion mesh. That can lead to to premature wear, gear whine etc.... If you do swap gears between different boxes, do it only as matched pairs. The gears are used to running together (ie worn together) and should remain matched. (One from the drive shaft and one from the driven shaft) Do swap dog teeth and friction bands around. They do not interfere in the shaft stackup and can be swapped around between locations in a gearbox and between different transmisions. Go with the best parts. And, hows about a little dialogue on replacing bearings in the intermediate bearing plate and/or the angled bearings in the differential. I owe you a picture of a tool. I found a punch that is perfect for removing the roll pin from the small first gear castellated nut. Ken Some of this is only going to be in the video, but I can list the donts in the notes. |
Dr Evil |
Special tool list please. Reasonable substitutes for special tools. (IMG:style_emoticons/default/idea.gif)This is a problem area in that I have some modified tools, but for that actual special tools, I only use the correct tools. Using anything else can be dangerous to you and your parts. I havent used many substitutions so I really cant comment. |
Dr Evil |
I know you producing a DVD, but how about also cranking out a blue ray disk while your at it...not really any more work--you'll be able to include much more. Of course, the blue ray disk could be a premium purchase. Just think of all the cool interactivity that could be incorporated., humor cameos, diagram blowups, step by step lists, websites, interviews, etc, etc. I'll see if Eric has any idea about this. I dont know squat about Blue ray and if the format gets changed again I will quit buying video media all together (IMG:style_emoticons/default/mad.gif) I just got on with DVD when blueray came out. |
turboman808 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,718 Joined: 31-January 06 From: North Jersey Member No.: 5,505 Region Association: North East States ![]() |
I'll see if Eric has any idea about this. I dont know squat about Blue ray and if the format gets changed again I will quit buying video media all together (IMG:style_emoticons/default/mad.gif) I just got on with DVD when blueray came out. BluRay is alot of work. Then in the end everyone will buy the DVD. (IMG:style_emoticons/default/dry.gif) Plenty of other options but DVD still seems top be the most universal. Working to setup Super Speeders for download with digital rights management. What a pain in the ass that is. If you guys need help I have a scribe replicator. Does 400 disc a day and prints full color disc art. Only does single layer though. In my experience if you go dual layer you need to go full replication from DLT tape. Easier to multiple single disc. (IMG:http://www.proactionmedia.com/prodimages/Scribe-9000/mfdigital-Scribe-9000.jpg) |
Dr Evil |
I'll see if Eric has any idea about this. I dont know squat about Blue ray and if the format gets changed again I will quit buying video media all together (IMG:style_emoticons/default/mad.gif) I just got on with DVD when blueray came out. BluRay is alot of work. Then in the end everyone will buy the DVD. (IMG:style_emoticons/default/dry.gif) Plenty of other options but DVD still seems top be the most universal. Working to setup Super Speeders for download with digital rights management. What a pain in the ass that is. If you guys need help I have a scribe replicator. Does 400 disc a day and prints full color disc art. Only does single layer though. In my experience if you go dual layer you need to go full replication from DLT tape. Easier to multiple single disc. (IMG:http://www.proactionmedia.com/prodimages/Scribe-9000/mfdigital-Scribe-9000.jpg) I am not sure what we will need for distribution. I have Eric linked to this as I am pretty much the on screen talent and he is the guy with the smarts to do the rest. I would be floored if we sold 400, probably more like 100, but we will see (IMG:style_emoticons/default/smile.gif) |
bandjoey |
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,934 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region ![]() |
It'd only take about a weeks worth of production to make one for all the running 914's in existence. (IMG:style_emoticons/default/biggrin.gif)
Don't forget the hammer on the thumb outtakes! (IMG:style_emoticons/default/lol-2.gif) Don't know beans about a tranny, but will be looking to watching the video. Bill |
Dr Evil |
I hope it is not just informative, but also entertaining. (IMG:style_emoticons/default/smile.gif)
Dr Evil |
OK, Folks! The date for shooting this has been set for March 6th (IMG:style_emoticons/default/smile.gif) If needed, there will be other dates to finish shooting. This is gonna be so fun!
Lo-Fi Version | Time is now: 2nd July 2025 - 05:30 PM |
