2 Pages V < 1 2
> Front Brakes Dragging, wheels don't spin free
topatrout914
post Jan 28 2010, 10:09 AM
Post #21
Trout
Make sure you did not overtighten the spindle nut. It causes drag and premature bearing failure if overtightened. This would be a contributing factor but would have to be tightened by a gorilla to cause the kind of drag you describe. It very likely could be the rubber hoses, if your not sure of their age its cheap insurance to change 'em out.
Trout (IMG:style_emoticons/default/driving.gif)
ME733
post Jan 28 2010, 01:48 PM
Post #22
I purchased the "expanding Springs,".... and new pins from AA- george Hussy about three months ago.....FRONT....r90135191616..expanding .spring set ........REAR..r311615269 expanding spring set ...the sets include new pins....murray.
7TPorsh
post Jan 28 2010, 02:19 PM
Post #23
7T Porsh
i looked at Pelican, it looks like they only have the rear listed. AA has the front. I am puzzled why a Genuine part is way less than a repro. Are they used?
I am going to break it all down this weekend and take in all this advice. I do have a set of hoses that I will replace as well. We'll see how it goes...
914rrr
post Oct 23 2026, 12:28 PM
Post #24
Resurrecting an older thread that eliminates some issues I've already (mostly) addressed / ruled out.
I'm changing out my front brakes pads after bleeding them repeatedly for the rear caliper rebuild(s) I just completed. Both front discs are worn evenly and the front pads were very worn down. I was able to push back the caliper pistons but they required a good bit of coaxing to do so. I inserted the new pads and both discs were spinning freely until I applied the brakes. Now both front discs are stuck / calipers are definitely sticking.
IIRC, there was a mention in the Haynes manual about removing the pads and inserting a piece of wood thinner than the pad and pushing the pedal, manually pushing back the piston back, push pedal, push piston back, rinse, repeat, to free up the stubborn pistons. Is there a better / alternative method for freeing up the pistons?
I'm OOT for work now. I don't have the manual with me and I won't get home until midnight this PM, so anything to speed things up helps. I was planning on driving my teener to a VW show on Saturday and freeing up the caliper pistons is the last task (besides reinstalling the wheels) to get it trip worthy. TIA!!
2 Pages V < 1 2
4 User(s) are reading this topic (3 Guests and 0 Anonymous Users)
1 Members: T.Rick6
- Lo-Fi Version Time is now: 23rd October 2026 - 04:42 PM
