Injecting you car the EFI way |
Mike Bellis |
Jan 27 2010, 09:30 PM
I work on very complex fuel systems for a living. For fun I enjoy building EFI systems for myself and clients. I have had some inquiries about how to DIY a system. So here anre some pics and a few words... I'll break it down for those not up to speed.
You will see my current project. Don't worry about the wiring. It's still in test phase and I have a shorter harness I'm working on. This is a TBI (Throttle Body Injection system. The easyest way by far to add EFI to your engine. Here's a list of sensors needed for most EFI setups... TPS (Throttle Position Sensor) The TPS measures how far open your throttle is. 1-5 volts in mots cases. MAP (Manifold Absolute Pressure sensor) Measures manifold vacuum 1-5 volts. AIT (Air Intake Temp sensor) Measures intake ait temp. Used for TPI or sequencial systems. Not needed for TBI. Water Temp. Most aftermarket system use a GM sensor. O2 sensor (measures the ammount of oxygen in the burned exhaust. ECU will adjust fuel level based on this signal) Oil Pressure Switch. Some systems like the TBI use this switch to shut off fuel with a loss of oil pressure. MAF (Mass Air Flow sensor) Measures the amount of air going into the engine. Used on high performance systems. Crank Trigger. Used by the ECU to determine engine speed and adjust the fuel map to suit the engine requirements. Cam Trigger. Used buy the ECU for a sequencial injection system. ECU (Electronic Control Unit, the brain of the system) The TBI system has the injectors mounted in the throttle body on top of the engine. It mounts similar to a carb. These systems can be used on a stock manifold with the correct adapter flange. The TBI is for a mild cam setup but the ECU can be re-flashed for more performance. In the picture above is a Crossfire Injection system from an 80's Corvette. It uses two 400 CFM TB's instead of one. I had to down size the injectors for my 283. The GM computer will learn how the car drives and re-write the fuel map to suit the engine (Closed Loop) using the engine sensors as a referance. During warm up and WOT, the system will run in "Open Loop" mode and use engine speed and TPS signal to adjust the fuel map. This system was used and purchased from Ebay. Total installed price $500. A sequencial injection system uses both the Crank and Cam signals to determine when each cylinder is at its intake stroke. The injector will fire only during this point of the cycle. A sequencial system has better off idle performance and slightly better fuel economy. The two most common ways to access a Cam signal are to use an Accel Dizzy with a cam output or machine a magnet into the cam gear to use an inductive pickup on the timing cover. This Picture Is a sequencial system using a F.A.S.T. ECU, GM sensors, Ford dual throttle bodies and Bosch Injectors. For This setup everything was custom fabricated. I used a dual quad manifold and welded injector bungs to it. This system was all new parts. Total installed price $4000. Plus dozens of days of seat time with my lap top writing fuel maps. I've also used Megasquirt with great results. MS has a great fourm with helpful people just like this site. MS does not need a cam signal because it does not do sequencial injection. MS uses "Bank to Bank" injection. This means to toggles between the right and left cylinders back and forth. There will be slightly lesss performance at low RPM's but at mid to high rpm the difference is neglegable. The really nice thing about the MS forum is that there will be someonr there with a setup similar to yours and they will share their fuel maps. You then use their map as the starting point for yours. Most aftermarket EFI systems will allow the use of a wide band O2 sensor. A wide band O2 will allow you to run in Closed Loop mode and have the ECU learn how you drive in conjunction with the engine needs. This makes fine tuning of the system very easy. Most early GM EFI systems can be adapted to any engine. You just need the GM sensors and wire it up correctly. Factory EFI systems are really cheap at junk yards or on the web. Make sure you buy a system as complete as possible. Painless Wiring makes harnesses for most GM and Ford systems. I hope this helps people understand a little about EFI. If I missed anything please chime in. Correct me if I made any mistakes. Bottom line... EFI is easy. Everyone should do it! |
detoxcowboy |
Jan 27 2010, 09:41 PM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
Glad to see an Electrician on this site, my father was less electroincs but a union local president.. I bet you can build a crazy audio system for the 914 in your sleep..
Mike Bellis |
Jan 27 2010, 09:54 PM
Glad to see an Electrician on this site, my father was less electroincs but a union local president.. I bet you can build a crazy audio system for the 914 in your sleep.. IBEW Local 595 I've done a few stereo's in my time. I'm a former IASCA judge (International Auto Sound Challenge Association) |
underthetire |
Jan 27 2010, 10:24 PM
Cool, looks like the '82 corvette cross fire injection. And there are quite a few of us on here running megasquirt 1 and 2. My brother does a lot of tuned port stuff in dallas for show cars. I love FI !
76-914 |
Jan 27 2010, 10:35 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,483 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Great reading. THX. A good terminology reference for FI imbeciles such as myself. You know what would be neat? An DIY article on which GM junkyard FI fits our basic T4's e.g. 1.7, 1.8, 2.0 and a step by step article on how to install and dial one of these units in. With our antiquated FI systems wearing out every day, we would enshrine you. Especially if we coud do this on the cheap!
underthetire |
Jan 27 2010, 10:42 PM
Great reading. THX. A good terminology reference for FI imbeciles such as myself. You know what would be neat? An DIY article on which GM junkyard FI fits our basic T4's e.g. 1.7, 1.8, 2.0 and a step by step article on how to install and dial one of these units in. With our antiquated FI systems wearing out every day, we would enshrine you. Especially if we coud do this on the cheap! Can be done for less than a set of new carbs, but you would really need to DIY. My install cost me less than 300 for the megasquirt. I was able to get free sensors though. If you did a real diy and bought new sensors, still less than 500. DIY injection is not for people that don't like to tinker or learn. If your in the latter group, pay someone like kg6dxn to do it! |
Mike Bellis |
Jan 27 2010, 10:51 PM
Great reading. THX. A good terminology reference for FI imbeciles such as myself. You know what would be neat? An DIY article on which GM junkyard FI fits our basic T4's e.g. 1.7, 1.8, 2.0 and a step by step article on how to install and dial one of these units in. With our antiquated FI systems wearing out every day, we would enshrine you. Especially if we coud do this on the cheap! If I had a T4 engine, I could do it. The best EFI to use would be a TBI setup and operate it as a bank to bank system. Connecting the TBI's injector outputs to the T4's injectors. It's been a while since I had an air cooled engine. not sure what the oil temp is at operating temperature. If it is around 190, the GM water temp sensor could be taped into the bottom of the block in the oil sump. A TPS cam would need to be fabbed on the throttle body. any 3 wire TPS that would fit would work. If we were crazy enough to run Nitrous Oxide, the ECU can be programmed to increase fuel delivery automatically. And... if you run a spark controller with the ECU, it can retard the timing at the same time. I love technology. |
underthetire |
Jan 27 2010, 11:12 PM
oil temps around 225, but thats not what you want to monitor. Its head temp, the oil takes way to long to come up to temp, so you would be in cold start mode too long.
I was able to use stock plenum, and TB (new 53MM GM waiting to go in) with stock injectors and head temp sensor. What I got was... MS2 V3.0 diy kit in black 254.00 GM throttle position sensor, modified throttle body shaft to accept it. about 30.00 GM air temp sensor about 12.00 Universal 4 wire heated Bosch O2 sensor about 55.00 Welded in O2 sensor bung 8.00 Lots of wire or buy the harness available for the MS about 50.00 This is all fuel only, ignition requires a little more work, but not terrible. If you want to go crank trigger with a coil pack that adds more $$$ What does all this do for you? No more antique map/pressure sensor No more expensive throttle position switches No more expensive trigger points Modern programable ECU that you can test/monitor/tune through your laptop Here is he big one though. My time in assembling the MS2 8 or so hours Wire harness fab 4 hours sensor fitment/adaptation 5 hours tuning first start up 2 hours READING THE MEGAMANUAL 30+hours ! Keep in mind I make full CNC panels and do board level repair at work, so i'm probably a little faster than most. |
Mike Bellis |
Jan 27 2010, 11:29 PM
[quote
Keep in mind I make full CNC panels and do board level repair at work, so i'm probably a little faster than most. [/quote] I'm a licensed FCC technician, went through solder school, electronics school etc, etc... I used to build the MS myself but now I pay a little more and have one built for me. I do the board mods myself. Like MAF and WB O2. I just don't have the time or paitence to solder all that crap anymore. |
underthetire |
Jan 27 2010, 11:50 PM
[quote name='kg6dxn' date='Jan 27 2010, 09:29 PM' post='1266545']
[quote Keep in mind I make full CNC panels and do board level repair at work, so i'm probably a little faster than most. [/quote] I'm a licensed FCC technician, went through solder school, electronics school etc, etc... I used to build the MS myself but now I pay a little more and have one built for me. I do the board mods myself. Like MAF and WB O2. I just don't have the time or paitence to solder all that crap anymore. [/quote] I don't blame you ! For a one time thing it was kinda fun, but not more than one ! |
ghuff |
Jan 28 2010, 02:15 AM
This is certainly not what I expected down here. Group: Members Posts: 849 Joined: 21-May 09 From: Bodymore Murderland Member No.: 10,389 Region Association: MidAtlantic Region |
I like that, but TBI is obsolete since you can get a batch fire system so cheap now, especially for a fuelie type IV.
Really, with gas where it is and going higher, I would only do sequential stuff from now on. Batch sucks ass too when you hit the injector wall, it is hard getting large injectors to do well on batch systems, then there is wasted fuel, more oil changes more often due to gas contaminated oil which can wipe rings, etc etc. |
toon1 |
Jan 28 2010, 08:56 PM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
[quote Keep in mind I make full CNC panels and do board level repair at work, so i'm probably a little faster than most. [/quote] I'm a licensed FCC technician, went through solder school, electronics school etc, etc... I used to build the MS myself but now I pay a little more and have one built for me. I do the board mods myself. Like MAF and WB O2. I just don't have the time or paitence to solder all that crap anymore. [/quote] [quote name='underthetire' date='Jan 27 2010, 09:50 PM' post='1266559'] [quote name='kg6dxn' date='Jan 27 2010, 09:29 PM' post='1266545'] [quote Keep in mind I make full CNC panels and do board level repair at work, so i'm probably a little faster than most. [/quote] I'm a licensed FCC technician, went through solder school, electronics school etc, etc... I used to build the MS myself but now I pay a little more and have one built for me. I do the board mods myself. Like MAF and WB O2. I just don't have the time or paitence to solder all that crap anymore. [/quote] I don't blame you ! For a one time thing it was kinda fun, but not more than one ! [/quote] Can either one of you guy's do trouble shooting? I am having a prob. with my MS not switching the fast idle selonoid on and off. TBI on a 914 engine (in my opinion) is not practical due to the fact that they where injected from the factory. parts are easily obtainable. Although, a MS retro fit is a great solution for the aging stock parts. I love FI and messing around with the MS system. I did a full retorofit with crank fire using Ford escort parts. Soon I will be converting a 32hp twin cylinder engine from carbs to FI. I'm going to use microsquirt for the controller. |
underthetire |
Jan 28 2010, 09:08 PM
Is it drivable yet? If you are using a fast idle solenoid not the stock aar valve, then it would have to be one of the aux ports on the ECU. I can meet you at work next week. Should be at 801 if you know what I mean. (IMG:style_emoticons/default/rolleyes.gif)
Mike Bellis |
Jan 28 2010, 10:35 PM
I like that, but TBI is obsolete since you can get a batch fire system so cheap now, especially for a fuelie type IV. Really, with gas where it is and going higher, I would only do sequential stuff from now on. Batch sucks ass too when you hit the injector wall, it is hard getting large injectors to do well on batch systems, then there is wasted fuel, more oil changes more often due to gas contaminated oil which can wipe rings, etc etc. I agree there are better systems to ues as a custom 914 replacement. The challenge was to use a GM junk yard EFI system. A TBI ECU can be used to batch fire the 14's injectors. I was not thinking of using the TBI's throttle body, just the injector outputs. If the impedance is high enough on the 914 injectors, you can simply use two per TBI injector output. Mainly you would need the ECU and harness from the junk yard. A few misc sensors too. Sequencial is a little tricky for any custom setup due to the need of a cam signal to sync the injector fire. The 914 dizzy does not sync with the intake valves opening. It only give an on/off signal the the ECU that matches mechanical engine speed. |
aircooledtechguy |
Jan 29 2010, 11:52 AM
Sequencial is a little tricky for any custom setup due to the need of a cam signal to sync the injector fire. The 914 dizzy does not sync with the intake valves opening. It only give an on/off signal the the ECU that matches mechanical engine speed. I'm rather new to the whole custom EFI relm and am still in the tuning phase of an MS2 w/ EDIS conversion, so please excuse the possibly dumb questions. . . If you're running a crank fired ignition like EDIS, where you would normally omit the dizzy and plug the hole, why could you not use the un-used ignition points (not the trigger points for the D-jet EFI) as your cam position sensor?? The rotor can be positioned in any position by moving the drive gear, underneath it, a tooth or two back and then fine tune the exact moment of fire like you would when setting the timing on a motor. . . You would effectively have now a sensor that gives you one pulse per intake opening event that is tunable (well in my mind anyway (IMG:style_emoticons/default/idea.gif) ). Does that sound like a possible solution or have I just sniffed too much fuel?? (IMG:style_emoticons/default/screwy.gif) |
Mike Bellis |
Jan 29 2010, 05:31 PM
Sequencial is a little tricky for any custom setup due to the need of a cam signal to sync the injector fire. The 914 dizzy does not sync with the intake valves opening. It only give an on/off signal the the ECU that matches mechanical engine speed. I'm rather new to the whole custom EFI relm and am still in the tuning phase of an MS2 w/ EDIS conversion, so please excuse the possibly dumb questions. . . If you're running a crank fired ignition like EDIS, where you would normally omit the dizzy and plug the hole, why could you not use the un-used ignition points (not the trigger points for the D-jet EFI) as your cam position sensor?? The rotor can be positioned in any position by moving the drive gear, underneath it, a tooth or two back and then fine tune the exact moment of fire like you would when setting the timing on a motor. . . You would effectively have now a sensor that gives you one pulse per intake opening event that is tunable (well in my mind anyway (IMG:style_emoticons/default/idea.gif) ). It could be possible if you sync the points with the intake stroke. Then you could do sequencial injection and coil on plug technology. I too enjoy the latest technology in fuel and spark. I would prefer of course not to see the dizzy at all. You could custom maching a flat cap to cover the points in the dizzy. If you would go to all this trouble, why not just maching a magnet into the cam gear. BMW crank and cam sensors are cheap and east to mount to the engine. You would just need to find a good spot on the block to machine the hole for the sensor. The sensor could also be "clocked" on the gear to put in a convienient position. Making sure degrees BTDC/TDC is correct for the COP driver. Maybe it's time to build a radical turbo T4 sequencial EFI COP setup? Built in retard and boost controller??? Does that sound like a possible solution or have I just sniffed too much fuel?? (IMG:style_emoticons/default/screwy.gif) |
Dr Evil |
Jan 29 2010, 06:44 PM
Send me your transmission! Group: Members Posts: 22,993 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Very cool (IMG:style_emoticons/default/thumb3d.gif)
I look forward to doing this to my corvair engine some day (IMG:style_emoticons/default/smile.gif) I was thinking CIS, but I like to program. Attached image(s) |
Mike Bellis |
Jan 29 2010, 06:59 PM
Very cool (IMG:style_emoticons/default/thumb3d.gif) I look forward to doing this to my corvair engine some day (IMG:style_emoticons/default/smile.gif) I was thinking CIS, but I like to program. I'm thinking you should weld some injector bungs on and use a Ford 5.0 Throttle body in place of that carb. If you look at my dual throttle body pic you will see a 90 degree adapter to go from a 4 barrel manifold to the 5.0 TB. They cost about $50 each. I would also recomend a lamda wide band O2 so you can have the system fine toue you fuel map automatically. Having the engine run at stoich at all rpms is amazing. ..vroom (IMG:style_emoticons/default/driving.gif) |
Dr Evil |
Jan 29 2010, 07:23 PM
I currently have a WB O2 sensor setup for the electrically adjustable jet kit in the 390cfm carb. Would a 5.0 part not be too big for my 3.1L engine?
Mike Bellis |
Jan 29 2010, 07:27 PM
I currently have a WB O2 sensor setup for the electrically adjustable jet kit in the 390cfm carb. Would a 5.0 part not be too big for my 3.1L engine? The size of the throttle body does not matter as long as the fuel mixture is stoich. If you use one that is too small, you will have performance problems. I could fab four 50mm TB's, one to each cylinder as long as I size the injector and pulse width correctly. (IMG:style_emoticons/default/aktion035.gif) |
Lo-Fi Version | Time is now: 18th April 2024 - 09:17 PM |
