Injecting you car the EFI way |
Mike Bellis |
Jan 27 2010, 09:30 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
I work on very complex fuel systems for a living. For fun I enjoy building EFI systems for myself and clients. I have had some inquiries about how to DIY a system. So here anre some pics and a few words... I'll break it down for those not up to speed.
You will see my current project. Don't worry about the wiring. It's still in test phase and I have a shorter harness I'm working on. This is a TBI (Throttle Body Injection system. The easyest way by far to add EFI to your engine. Here's a list of sensors needed for most EFI setups... TPS (Throttle Position Sensor) The TPS measures how far open your throttle is. 1-5 volts in mots cases. MAP (Manifold Absolute Pressure sensor) Measures manifold vacuum 1-5 volts. AIT (Air Intake Temp sensor) Measures intake ait temp. Used for TPI or sequencial systems. Not needed for TBI. Water Temp. Most aftermarket system use a GM sensor. O2 sensor (measures the ammount of oxygen in the burned exhaust. ECU will adjust fuel level based on this signal) Oil Pressure Switch. Some systems like the TBI use this switch to shut off fuel with a loss of oil pressure. MAF (Mass Air Flow sensor) Measures the amount of air going into the engine. Used on high performance systems. Crank Trigger. Used by the ECU to determine engine speed and adjust the fuel map to suit the engine requirements. Cam Trigger. Used buy the ECU for a sequencial injection system. ECU (Electronic Control Unit, the brain of the system) The TBI system has the injectors mounted in the throttle body on top of the engine. It mounts similar to a carb. These systems can be used on a stock manifold with the correct adapter flange. The TBI is for a mild cam setup but the ECU can be re-flashed for more performance. In the picture above is a Crossfire Injection system from an 80's Corvette. It uses two 400 CFM TB's instead of one. I had to down size the injectors for my 283. The GM computer will learn how the car drives and re-write the fuel map to suit the engine (Closed Loop) using the engine sensors as a referance. During warm up and WOT, the system will run in "Open Loop" mode and use engine speed and TPS signal to adjust the fuel map. This system was used and purchased from Ebay. Total installed price $500. A sequencial injection system uses both the Crank and Cam signals to determine when each cylinder is at its intake stroke. The injector will fire only during this point of the cycle. A sequencial system has better off idle performance and slightly better fuel economy. The two most common ways to access a Cam signal are to use an Accel Dizzy with a cam output or machine a magnet into the cam gear to use an inductive pickup on the timing cover. This Picture Is a sequencial system using a F.A.S.T. ECU, GM sensors, Ford dual throttle bodies and Bosch Injectors. For This setup everything was custom fabricated. I used a dual quad manifold and welded injector bungs to it. This system was all new parts. Total installed price $4000. Plus dozens of days of seat time with my lap top writing fuel maps. I've also used Megasquirt with great results. MS has a great fourm with helpful people just like this site. MS does not need a cam signal because it does not do sequencial injection. MS uses "Bank to Bank" injection. This means to toggles between the right and left cylinders back and forth. There will be slightly lesss performance at low RPM's but at mid to high rpm the difference is neglegable. The really nice thing about the MS forum is that there will be someonr there with a setup similar to yours and they will share their fuel maps. You then use their map as the starting point for yours. Most aftermarket EFI systems will allow the use of a wide band O2 sensor. A wide band O2 will allow you to run in Closed Loop mode and have the ECU learn how you drive in conjunction with the engine needs. This makes fine tuning of the system very easy. Most early GM EFI systems can be adapted to any engine. You just need the GM sensors and wire it up correctly. Factory EFI systems are really cheap at junk yards or on the web. Make sure you buy a system as complete as possible. Painless Wiring makes harnesses for most GM and Ford systems. I hope this helps people understand a little about EFI. If I missed anything please chime in. Correct me if I made any mistakes. Bottom line... EFI is easy. Everyone should do it! |
underthetire |
Jan 27 2010, 11:12 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
oil temps around 225, but thats not what you want to monitor. Its head temp, the oil takes way to long to come up to temp, so you would be in cold start mode too long.
I was able to use stock plenum, and TB (new 53MM GM waiting to go in) with stock injectors and head temp sensor. What I got was... MS2 V3.0 diy kit in black 254.00 GM throttle position sensor, modified throttle body shaft to accept it. about 30.00 GM air temp sensor about 12.00 Universal 4 wire heated Bosch O2 sensor about 55.00 Welded in O2 sensor bung 8.00 Lots of wire or buy the harness available for the MS about 50.00 This is all fuel only, ignition requires a little more work, but not terrible. If you want to go crank trigger with a coil pack that adds more $$$ What does all this do for you? No more antique map/pressure sensor No more expensive throttle position switches No more expensive trigger points Modern programable ECU that you can test/monitor/tune through your laptop Here is he big one though. My time in assembling the MS2 8 or so hours Wire harness fab 4 hours sensor fitment/adaptation 5 hours tuning first start up 2 hours READING THE MEGAMANUAL 30+hours ! Keep in mind I make full CNC panels and do board level repair at work, so i'm probably a little faster than most. |
Mike Bellis |
Jan 27 2010, 11:29 PM
[quote
Keep in mind I make full CNC panels and do board level repair at work, so i'm probably a little faster than most. [/quote] I'm a licensed FCC technician, went through solder school, electronics school etc, etc... I used to build the MS myself but now I pay a little more and have one built for me. I do the board mods myself. Like MAF and WB O2. I just don't have the time or paitence to solder all that crap anymore. |
underthetire |
Jan 27 2010, 11:50 PM
[quote name='kg6dxn' date='Jan 27 2010, 09:29 PM' post='1266545']
[quote Keep in mind I make full CNC panels and do board level repair at work, so i'm probably a little faster than most. [/quote] I'm a licensed FCC technician, went through solder school, electronics school etc, etc... I used to build the MS myself but now I pay a little more and have one built for me. I do the board mods myself. Like MAF and WB O2. I just don't have the time or paitence to solder all that crap anymore. [/quote] I don't blame you ! For a one time thing it was kinda fun, but not more than one ! |
Lo-Fi Version | Time is now: 17th May 2024 - 09:39 AM |
