Injecting you car the EFI way |
Mike Bellis |
Jan 27 2010, 09:30 PM
I work on very complex fuel systems for a living. For fun I enjoy building EFI systems for myself and clients. I have had some inquiries about how to DIY a system. So here anre some pics and a few words... I'll break it down for those not up to speed.
You will see my current project. Don't worry about the wiring. It's still in test phase and I have a shorter harness I'm working on. This is a TBI (Throttle Body Injection system. The easyest way by far to add EFI to your engine. Here's a list of sensors needed for most EFI setups... TPS (Throttle Position Sensor) The TPS measures how far open your throttle is. 1-5 volts in mots cases. MAP (Manifold Absolute Pressure sensor) Measures manifold vacuum 1-5 volts. AIT (Air Intake Temp sensor) Measures intake ait temp. Used for TPI or sequencial systems. Not needed for TBI. Water Temp. Most aftermarket system use a GM sensor. O2 sensor (measures the ammount of oxygen in the burned exhaust. ECU will adjust fuel level based on this signal) Oil Pressure Switch. Some systems like the TBI use this switch to shut off fuel with a loss of oil pressure. MAF (Mass Air Flow sensor) Measures the amount of air going into the engine. Used on high performance systems. Crank Trigger. Used by the ECU to determine engine speed and adjust the fuel map to suit the engine requirements. Cam Trigger. Used buy the ECU for a sequencial injection system. ECU (Electronic Control Unit, the brain of the system) The TBI system has the injectors mounted in the throttle body on top of the engine. It mounts similar to a carb. These systems can be used on a stock manifold with the correct adapter flange. The TBI is for a mild cam setup but the ECU can be re-flashed for more performance. In the picture above is a Crossfire Injection system from an 80's Corvette. It uses two 400 CFM TB's instead of one. I had to down size the injectors for my 283. The GM computer will learn how the car drives and re-write the fuel map to suit the engine (Closed Loop) using the engine sensors as a referance. During warm up and WOT, the system will run in "Open Loop" mode and use engine speed and TPS signal to adjust the fuel map. This system was used and purchased from Ebay. Total installed price $500. A sequencial injection system uses both the Crank and Cam signals to determine when each cylinder is at its intake stroke. The injector will fire only during this point of the cycle. A sequencial system has better off idle performance and slightly better fuel economy. The two most common ways to access a Cam signal are to use an Accel Dizzy with a cam output or machine a magnet into the cam gear to use an inductive pickup on the timing cover. This Picture Is a sequencial system using a F.A.S.T. ECU, GM sensors, Ford dual throttle bodies and Bosch Injectors. For This setup everything was custom fabricated. I used a dual quad manifold and welded injector bungs to it. This system was all new parts. Total installed price $4000. Plus dozens of days of seat time with my lap top writing fuel maps. I've also used Megasquirt with great results. MS has a great fourm with helpful people just like this site. MS does not need a cam signal because it does not do sequencial injection. MS uses "Bank to Bank" injection. This means to toggles between the right and left cylinders back and forth. There will be slightly lesss performance at low RPM's but at mid to high rpm the difference is neglegable. The really nice thing about the MS forum is that there will be someonr there with a setup similar to yours and they will share their fuel maps. You then use their map as the starting point for yours. Most aftermarket EFI systems will allow the use of a wide band O2 sensor. A wide band O2 will allow you to run in Closed Loop mode and have the ECU learn how you drive in conjunction with the engine needs. This makes fine tuning of the system very easy. Most early GM EFI systems can be adapted to any engine. You just need the GM sensors and wire it up correctly. Factory EFI systems are really cheap at junk yards or on the web. Make sure you buy a system as complete as possible. Painless Wiring makes harnesses for most GM and Ford systems. I hope this helps people understand a little about EFI. If I missed anything please chime in. Correct me if I made any mistakes. Bottom line... EFI is easy. Everyone should do it! |
ghuff |
Jan 28 2010, 02:15 AM
This is certainly not what I expected down here. Group: Members Posts: 849 Joined: 21-May 09 From: Bodymore Murderland Member No.: 10,389 Region Association: MidAtlantic Region |
I like that, but TBI is obsolete since you can get a batch fire system so cheap now, especially for a fuelie type IV.
Really, with gas where it is and going higher, I would only do sequential stuff from now on. Batch sucks ass too when you hit the injector wall, it is hard getting large injectors to do well on batch systems, then there is wasted fuel, more oil changes more often due to gas contaminated oil which can wipe rings, etc etc. |
Mike Bellis |
Jan 28 2010, 10:35 PM
I like that, but TBI is obsolete since you can get a batch fire system so cheap now, especially for a fuelie type IV. Really, with gas where it is and going higher, I would only do sequential stuff from now on. Batch sucks ass too when you hit the injector wall, it is hard getting large injectors to do well on batch systems, then there is wasted fuel, more oil changes more often due to gas contaminated oil which can wipe rings, etc etc. I agree there are better systems to ues as a custom 914 replacement. The challenge was to use a GM junk yard EFI system. A TBI ECU can be used to batch fire the 14's injectors. I was not thinking of using the TBI's throttle body, just the injector outputs. If the impedance is high enough on the 914 injectors, you can simply use two per TBI injector output. Mainly you would need the ECU and harness from the junk yard. A few misc sensors too. Sequencial is a little tricky for any custom setup due to the need of a cam signal to sync the injector fire. The 914 dizzy does not sync with the intake valves opening. It only give an on/off signal the the ECU that matches mechanical engine speed. |
Lo-Fi Version | Time is now: 16th May 2024 - 08:11 PM |
