Throttle Body Removal, from the plenum |
flat4tom |
Feb 4 2010, 06:27 PM
Member Group: Members Posts: 51 Joined: 6-January 10 From: Shingletown CA Member No.: 11,207 Region Association: Northern California |
Hello all,
I have a sticking throttle body. I've read thru all of the posts I can find about cleaning it and so forth. Haven't found anything about removing it. How do I remove the TB? Do I have to remove the plenum below it as well? I'd rather not if possible. Is it just two bolts on each side? Anything to watch out for like parts that like to fall out when it's removed? (IMG:style_emoticons/default/huh.gif) It's a '73 2.0 D-Jet. Thanks for any advise. Tom |
steveherman |
Feb 4 2010, 06:31 PM
Member Group: Members Posts: 380 Joined: 12-September 09 From: Kissimmee Florida Member No.: 10,799 Region Association: South East States |
Hello all, I have a sticking throttle body. I've read thru all of the posts I can find about cleaning it and so forth. Haven't found anything about removing it. How do I remove the TB? Do I have to remove the plenum below it as well? I'd rather not if possible. Is it just two bolts on each side? Anything to watch out for like parts that like to fall out when it's removed? (IMG:style_emoticons/default/huh.gif) It's a '73 2.0 D-Jet. Thanks for any advise. Tom yep remove air cleaner and two bolts. |
McMark |
Feb 4 2010, 07:48 PM
Check the Member Vendor forum for new gaskets.
Lo-Fi Version | Time is now: 17th May 2024 - 04:14 PM |
