changing fuel pump cam in 1600 dual port, what do i have to do(old VW content) |
pete-stevers |
Feb 11 2010, 09:38 PM
saved from fire! Group: Members Posts: 2,641 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
My old 59 single cab has a 1600 dual port engine ..and I suspect the fuel pump cam is gone...but what do i have to do to change it?
i bought a new pump already fuel from tank is fine spark is good no fuel coming out the carb side of the new pump push rod has little wear (i have little aircooled exp, cut my teeth on water cooled) |
Jake Raby |
Feb 11 2010, 09:42 PM
Rotate the engine and watch the function of the pushrod..
There are two different styles of pumps and two different pushrods, if the rod and pump do not match the pump won't function. Also some pumps today have opposite functioning inlets and outlets, you may have the fuel lines attached backward to the new pump.. The cams don't wear... They are part of the dizzy drive pinion |
pete-stevers |
Feb 11 2010, 09:43 PM
love this place!! you blink ....and there behold is the answer
thanks Jake |
P.Rocket |
Feb 12 2010, 02:14 AM
Member Group: Members Posts: 54 Joined: 17-March 08 From: Abbotsford BC Member No.: 8,822 Region Association: None |
Bleyseng |
Feb 12 2010, 08:02 AM
rick 918-S |
Feb 12 2010, 08:05 AM
Hey nice rack! -Celette Group: Members Posts: 20,460 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
pbanders |
Feb 12 2010, 09:07 AM
Senior Member Group: Members Posts: 939 Joined: 11-June 03 From: Phoenix, AZ Member No.: 805 |
While we're wating on pics, here's my buddy's dual cab restoration.
http://www.classicvws.com/dblcab.htm He found it in a fire station's parking lot in Sweeden, had it shipped to the US for the restoration. (IMG:http://www.classicvws.com/images/bludblcb-1.jpg) |
Cap'n Krusty |
Feb 12 2010, 09:11 AM
If you attempt to use the short throw pump with the long pushrod, you'll be needing another new pump. The Cap'n
aircooledtechguy |
Feb 12 2010, 10:51 AM
The generator pump (below) requires the longer push rod. Note the actuating lever is higher up inside the pump body (on the bottom)
The alternator style pump uses the shorter push rod. As the Cap't mentioned, you use the long rod with this pump and you'll get one good pump and it'll break on you. Note how the actuating lever actually comes below the base of the pump body. On this pump the upper nipple is the INLET and the bottom nipple is the OUTLET (it's the opposite of how you would logically think they should go). |
montoya 73 2.0 |
Feb 13 2010, 02:26 PM
Lack of consideration to others, and Selfish! Group: Members Posts: 1,791 Joined: 27-October 04 From: Paso Robles, Ca. Member No.: 3,016 Region Association: Central California |
The generator pump (below) requires the longer push rod. Note the actuating lever is higher up inside the pump body (on the bottom) The alternator style pump uses the shorter push rod. As the Cap't mentioned, you use the long rod with this pump and you'll get one good pump and it'll break on you. Note how the actuating lever actually comes below the base of the pump body. On this pump the upper nipple is the INLET and the bottom nipple is the OUTLET (it's the opposite of how you would logically think they should go). Hey Nate, Is that Brazilian stuff good now or is it "still" crap like in the late 80's and early 90's? If I recall correctly, the parts pecking order went German, Mexico then Brazil. I'm in the need to know cause I'm trying to convince someone to sell me their early bus. |
Cap'n Krusty |
Feb 13 2010, 02:57 PM
Actually, there are early and late "generator" pumps. Early ones take the long pushrod, later ones the short one. The "alternator" pumps are canted over like the one pictured, and they always use the short one.
Another thing to look for is whether opr not the pivot pin is locked into place. The old pumps had circlips, the late manufactured ones don't, and the pin slides right out after a few weeks or months. Bad news. The last one I bought had a "fix" designed. Unfortunately, I forget what it looked like ................. I've been hitting the ends of the pin with the mig welder. The Cap'n |
Lo-Fi Version | Time is now: 18th May 2024 - 03:39 AM |
