FS: Porsche 914 2.0L motor, nice relatively stock 2.0L motor |
Gunther |
Feb 12 2010, 11:37 AM
Racer from birth Group: Members Posts: 50 Joined: 1-June 09 From: Charlotte, NC area Member No.: 10,429 Region Association: South East States |
For Sale - Porsche 914 2.0L motor; (IMG:style_emoticons/default/piratenanner.gif)
This is a nice relatively stock 2.0L motor. This motor has less than 5000 miles on it since I built it at Black Forest Racing. This was my personal street/autocross motor that I built while I was working on the chassis and saving up for the 6 cylinder motor which is now in the car. It was mostly used to drive to car shows and autocrosses. It has always started and does not leak. This is a Plug and Play set up. In about 4 hours (theoretically) you could be driving down the road. I started out with a nice EA 1.7 case. It did not need line boring so it was good to go. The 2.0L crank was magnafluxed, polished and balanced. Naturally, new bearings all the way around. Connecting rods were all weighed with a triple beam scale within less than a half a gram. Brand New Mahle 2.0L European cylinders and higher compression Euro pistons, also weighed with a triple beam scale within less than a half a gram. A slightly hotter than standard carbureted Webb Cam was used. I forgot to write down the specs or grind number, but you can feel her kick at about 3000rpm. 2.0L heads were slightly ported, after all this is a street motor. A new Scat Deep Sump Oil pan is used to keep oil flowing at high corner speeds. Bosch Coil, Bosch Distributor and spark plugs fire this puppy up. Toped off with 2.0L sheet metal. It also comes with a Custom 10 ½ pound Fly Wheel that I turned down myself. You just can’t buy this any where. Stock fly wheels are normally 16 to18 pounds. It comes with a custom oil breather, oil breather lines and a Bug Pack breather tank. Motor mounts were bought new and comes with mounting bar and the nuts and bolts. Oops almost forgot the alternator. I was running the Engine with Weber 44IDF’s. They are great for autocross or high speed/high rpm driving. They were rebuilt about 1500 miles ago. Weber 40IDF’s would be better for regular street driving because it has better bottom end torque. GEX International offers this motor for $4899.00, but it does not come with the lightened fly wheel, motor mounts and bar, deep sump oil pan or the breather system. I know that I spent as much money and time as they do on my engine as well. I am offering this engine for sale with the Weber’s for $3750.00 Or $3250.00 without carbs. |
hot_shoe914 |
Feb 16 2010, 02:02 AM
on ramp passer Group: Members Posts: 3,802 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None |
How would this motor do with stock D-jet injection?
Gunther |
Feb 16 2010, 07:48 AM
It would work, but its not optimal. To get the best performance you would need to change back to a fuel injected cam. That would be the only modification you would need to do, to work with that system.
Weber 40s are the best way to go with this setup as is. It was realy peppy and strong with them. I liked it better than the 44s. It had better bottom end torque and worked well from 2000 to 5000rpm. The 44s worked better from 3000 to 6000rpm. |
Snave007 |
Jun 4 2014, 05:27 PM
Newbie Group: Members Posts: 4 Joined: 4-June 14 From: Kansas City Member No.: 17,437 Region Association: None |
Is the motor still available and if so may I have a phone number to speak wit you or call me at 210-422-4285.
Jeff1gil |
Jun 14 2014, 05:46 AM
I'm new here ... Group: Members Posts: 0 Joined: 14-June 14 From: United States Member No.: 17,485 Region Association: South East States |
Is this motor still available? Would you have access to a suitable transmission that would work with it, or know where I could get one?
Lo-Fi Version | Time is now: 20th May 2024 - 09:18 AM |
