sports seats, what do you use? |
qa1142 |
Feb 13 2010, 01:33 PM
Whiplash Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
Anyone use these?
http://www.exoticcarseats.com/ My drivers' seat core is cracked, have to do somthing this year... (IMG:style_emoticons/default/agree.gif) Will |
qa1142 |
Feb 13 2010, 02:16 PM
badm |
Feb 13 2010, 02:48 PM
Member Group: Members Posts: 213 Joined: 10-May 09 From: Cape Cod Taxachusetts Member No.: 10,350 Region Association: North East States |
GTS is fantastic! The owner Stefan is a stand up guy and a car nut as well. He will help you find the perfect seat for your car as well as your back. Just remember if you have a wast over 36" most of the 914 seats are to narrow. Ben. |
Rav914 |
Feb 13 2010, 03:11 PM
All-weather fan Group: Members Posts: 738 Joined: 15-April 07 From: WA Member No.: 7,669 Region Association: None |
I'm using a Scheel. It's very comfortable and supportive.
It looks like Koenig. But only because it was re-upholstered in materials not matching the original. Attached image(s) |
plymouth37 |
Feb 13 2010, 03:26 PM
Senior Member Group: Members Posts: 1,825 Joined: 24-May 05 From: Snoqualmie, WA Member No.: 4,138 Region Association: Pacific Northwest |
I have been lusting after these Carbon/Kevlar seats from Caterham, IIRC they are around 4lbs.
And yes, they cost more than my 914 did... |
qa1142 |
Feb 13 2010, 03:50 PM
Eric_Shea |
Feb 13 2010, 03:56 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
I used these...
This last one gives it away: ...yup, they're 914 seats. Dale Hancock of Hancock Upholstery poured over pictures of real GT seals and used the Recaro's in my 911 as a template base. He glassed in the side bolsters and matched the material and stitching of a Sheel GT seat from back in the day. |
underthetire |
Feb 13 2010, 04:32 PM
I have wide shoulders and a big belly. My car came with a schiel seat that jamie now has. Was not a option for me as a dd or weekend car.
sixaddict |
Feb 13 2010, 04:41 PM
Senior Member Group: Members Posts: 804 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
Ben
Really like yours ..How much if I may be so rude (pm ok) TOT |
underthetire |
Feb 13 2010, 04:47 PM
A Lincoln mark V is very comfy. (IMG:style_emoticons/default/poke.gif) I'm 245 with a 38 waist. Stock seats fit the best for me. |
qa1142 |
Feb 13 2010, 05:08 PM
figured someone would suggest SUV (IMG:style_emoticons/default/WTF.gif)
But I am down 12# and working on the little weight issue (IMG:style_emoticons/default/headbang.gif) And good stock seats are harder to find than after market seats (IMG:style_emoticons/default/screwy.gif) That said, if you live near Chicago and have good black Drivers seat (you do know that drivers and passengers are not the same) I would take it. Otherwise I will be buying one that will keep my 250# in place during autoX corners. No SUVs needed (IMG:style_emoticons/default/av-943.gif) |
underthetire |
Feb 13 2010, 05:22 PM
figured someone would suggest SUV (IMG:style_emoticons/default/WTF.gif) But I am down 12# and working on the little weight issue (IMG:style_emoticons/default/headbang.gif) And good stock seats are harder to find than after market seats (IMG:style_emoticons/default/screwy.gif) That said, if you live near Chicago and have good black Drivers seat (you do know that drivers and passengers are not the same) I would take it. Otherwise I will be buying one that will keep my 250# in place during autoX corners. No SUVs needed (IMG:style_emoticons/default/av-943.gif) A lot of guys use the stock ones, and AX with the cushion out. Gives you a little more support. |
badm |
Feb 13 2010, 06:19 PM
Ben Really like yours ..How much if I may be so rude (pm ok) TOT Nurburgring 5503 I think they are running about $845.00 Ea. Cant say enough good things about Stefan and GTS. Don't tell my wife. (IMG:style_emoticons/default/blink.gif) |
carr914 |
Feb 13 2010, 06:35 PM
Racer from Birth Group: Members Posts: 118,899 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
Rav914 |
Feb 13 2010, 08:02 PM
Eric,
Real nice seats. I've thought about something similar but never thought you could go that far with a stock seat. Thanks for posting. |
914Sixer |
Feb 13 2010, 09:48 PM
914 Guru Group: Members Posts: 8,897 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
GTS seats are made here in Texas.
turboman808 |
Feb 13 2010, 10:19 PM
Advanced Member Group: Members Posts: 2,718 Joined: 31-January 06 From: North Jersey Member No.: 5,505 Region Association: North East States |
I was always under the impression these seats were all made by the same company and sold thru different vendors. Going to order from GTS seats. Really want the leather LeMans seat installed before the end of April. It's not a necessity but it would be nice.
rfuerst911sc |
Feb 14 2010, 06:52 AM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
I'm curious about the use of 4/5 point harnesses with these seats. From some of the pics here it looks like some are using 4 point and there are no " holes " in the sides of the seats for the belts to go through. Looks like they go over the bolsters is that correct ? I assume that's acceptable for AX's and DE's ? So if using a 5 point you only have to alter the bottom seat cushion for a sub-belt right ? Just trying to learn. Thanks
sixaddict |
Feb 14 2010, 07:42 AM
MY two cents relative to PCA (and you may know this)
for DEs after market seats must have slots for belts. I had some period seats and sold them because wouldn't comply and thats what I wanted to do. Rationale is a couple of accidents resulted in belts separating and bad stuff occurred as the seat held them apart to far. While 914 seats are less likely for that to happen there was no considerarion. Assume AX is ok .......but not DE and thats (IMG:style_emoticons/default/sad.gif) TOT I'm curious about the use of 4/5 point harnesses with these seats. From some of the pics here it looks like some are using 4 point and there are no " holes " in the sides of the seats for the belts to go through. Looks like they go over the bolsters is that correct ? I assume that's acceptable for AX's and DE's ? So if using a 5 point you only have to alter the bottom seat cushion for a sub-belt right ? Just trying to learn. Thanks |
swl |
Feb 14 2010, 07:53 AM
Senior Member Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
This is my drivers seat. Bought it circa 1978. It is a Recarro designed for the 914. Sadly, I could only afford one at the time so the car always had mismatched seats. Not a total loss though - wife would have had a tough time with the Recaros when she was pregnant.
I'd love to find one of these for sale. I still have the drivers seat that I removed and it is good enough to please a CW but it is destined for the passenger seat as all three of my other seats are getting pretty rough. |
Lo-Fi Version | Time is now: 1st June 2024 - 04:10 PM |
