021.109.111B, camshaft timing gear |
Posts in this area are restricted to the following format. If you have a general question, please post it in the Garage.
1. All new threads MUST be titled with a part number only. (i.e. 901.351.801.17)
2. Thread description should be an english description of the part. (i.e. Brake Dust Shields)
3. Replies to the thread are only restricted by pertinence. Some examples are original finish of the part (painted, cad plated, etc), common failures (cracking at the mount points), repair information or tips, pictures (stock or custom), upgrades, etc.
If you have any questions regarding the rules of this forum, please PM McMark.
type47 |
Feb 14 2010, 11:27 AM
PET #
(note: will update and finish entry when I get back home) |
914Mike |
Apr 13 2011, 01:02 PM
Member Group: Members Posts: 330 Joined: 27-January 03 From: San Jose, CA Member No.: 198 |
Some important marks on the cam:
Timing Mark. The gear size stamp. Putting the wrong size gear into your case will result in too much/too little lash. A too large gear will "walk" up the crank gear when test fitting on the case half. It's easiest to just note what size the gear is when you first break the case open, and make sure to put the same size back in that case. (Finding a -5 cam to replace the one in the pic that had corrosion/cracks in the gear was a multi-month journey...) The pic in post 1 is of a -4 size. The numbers indicate size offset from standard, in 100ths of a mm. This is to accommodate differences in the dimensions of the crank and cam bores in the case. |
Lo-Fi Version | Time is now: 15th May 2024 - 01:04 PM |
