LS4 914 conversion on a Budget, I could use Help! |
porsha916 |
Feb 14 2010, 08:38 PM
Member Group: Members Posts: 214 Joined: 1-June 04 From: Greenwood, SC Member No.: 2,137 Region Association: None |
Hi, I am converting a 914 to a LS4 V8 on a budget (IMG:style_emoticons/default/biggrin.gif) , any help would be appreciated.
1. Flywheel, Clutch, Pressure Plate from Kennedy 2. I have a rebuilt trans with "H" gear 3. 5.3L cable throttle body 4. Ls1 wiring harness / ECU for standard trans 5. How do I delete speed sensor hookup Take Care Bill |
BIGKAT_83 |
Feb 15 2010, 11:37 AM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
Better check the motor mount location on the Ls4 engine. I think all of these are for tranverse mount FWD cars.
The LH6 is the same engine but used in the trucks, but it has variable displacement and maybe a pain to work with. All LS1 wiring harness are for the 24 tooth reluctor wheel. I think you will need one of the newer small computers and harness for the 54 tooth wheel. LS4 914 conversion on a Budget (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) Bob |
porsha916 |
Mar 2 2010, 09:21 PM
The LS4 has the standard motor mount 3 bolt pattern in the sides of the block.
I was going to at the oil pickup/Pan design to look for differences. The 06 impala only came with automatics, but it has a separate trans brain, but I don't know how they are functionally interconnected. I have a 914 with 215V8 in I am considering swapping the LS4. I payed $750 for the ls4 with 31K on it. Take Care Bill |
Krank |
Mar 2 2010, 10:39 PM
Member Group: Members Posts: 140 Joined: 11-October 09 From: Winnipeg, MB Member No.: 10,922 Region Association: Canada |
The LS4 has the standard motor mount 3 bolt pattern in the sides of the block. I was going to at the oil pickup/Pan design to look for differences. The 06 impala only came with automatics, but it has a separate trans brain, but I don't know how they are functionally interconnected. I have a 914 with 215V8 in I am considering swapping the LS4. I payed $750 for the ls4 with 31K on it. Take Care Bill Interested in selling the adapter plate and flywheel? |
Lo-Fi Version | Time is now: 25th May 2024 - 06:07 AM |
