engine wiring harness, identify connectors |
kwtruck |
Feb 14 2010, 08:54 PM
Newbie Group: Members Posts: 14 Joined: 27-January 10 From: cropwell, al. Member No.: 11,294 Region Association: None |
installing engine & computer wiring harness on a 1973 2L. there is a multi wire to a washer looking connector at rear of engine near cold start valve area. is it a ground or something else? also , where does the red wire from the aux air valve connect ? car belongs to my 91 year old dad and I have been enlisted to get it running. Thanks for any advice.
jimkelly |
Feb 14 2010, 09:29 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
Feb 14 2010, 11:41 PM
The ring connector is a ground. It has three tabs on it where you can plug spade connectors in, right?
The AAR wire goes to a single white wire on the engine harness, not the FI harness. The engine harness is the one that has the coil wires, the oil pressure sender wire, etc. in it. --DD |
kwtruck |
Feb 15 2010, 06:56 AM
many thanks, I think that will be the last of the hookups, now to see what happens when we apply power.
Lo-Fi Version | Time is now: 18th May 2024 - 05:03 AM |
