Surging |
Surging |
RonnieJ |
Feb 15 2010, 04:46 PM
RonnieJ Group: Members Posts: 230 Joined: 16-June 03 From: Sterling Heights, Michigan Member No.: 829 Region Association: Upper MidWest |
I have a 1.7 running dual webers and it will surge a little while at idol. It only comes up a couple hundred rpms's and then right back down.I want to find what the problem is and make it right...Any ideas? Carbs loading up?
dr914@autoatlanta.com |
Feb 15 2010, 04:50 PM
914 Guru Group: Members Posts: 7,869 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
I have a 1.7 running dual webers and it will surge a little while at idol. It only comes up a couple hundred rpms's and then right back down.I want to find what the problem is and make it right...Any ideas? Carbs loading up? If compression dwell timing are right on and not moving, then leanness caused by bad carb adjustment or a vacuum leak |
underthetire |
Feb 15 2010, 04:53 PM
or a sticking advance in the dizzy. And I hate American Idol.
RonnieJ |
Feb 15 2010, 04:59 PM
Thanks guys much appreciated.
Lo-Fi Version | Time is now: 23rd May 2024 - 06:55 AM |
