carbs, ??????????? |
statesblue |
Feb 16 2010, 07:44 AM
Newbie Group: Members Posts: 24 Joined: 4-August 08 From: Chino Valley Az Member No.: 9,386 Region Association: Southwest Region |
Would Weber 34 ICT work on a stock 1.7???? How well or would I need bigger????
IronHillRestorations |
Feb 16 2010, 08:04 AM
A pair would work OK, not optimum though.
sean_v8_914 |
Feb 16 2010, 08:18 AM
optimum would be EFI.
dual 34 ICTs work well on small engines. on a stock 1.7 with the stock cam I prefer them over a set of dual IDFs |
BarberDave |
Barberdave Group: Members Posts: 1,605 Joined: 12-January 03 From: Wauseon Ohio Member No.: 135 Region Association: Upper MidWest |
34's run better than the single center carb,that some seem to install. But you would be going from really bad to bad. Get a set of 40 idf's and all will be great. I have had all 3 , had major problems with the first 2 , 40's run great. PM me if you want more info than this! Good luck Dave |
Lo-Fi Version | Time is now: 18th May 2024 - 01:09 AM |
