> ATL area type IV megasquirt tuners?
thenewwazoo
post Feb 20 2010, 09:37 PM
Post #41
My (fairly new-to-me) megasquirted '74 2L is running warm on the highway, and I suspect an overly aggressive ignition map might be to blame. As well, it's got some spots in the fuelling that are still rough around the edges, and I don't think I've got the patience to do anything but DRIVE the damned thing (who wants to fiddle around with the laptop when I could be enjoying the car?).
As a result, I think I'd like to buy some dyno time with a tuner that's familiar with both the type IV and the MegaSquirt... does anyone have any recommendations?
For reference, I'm tuned for ~14.5 at cruise and about 36 degrees of advance at 3100 RPM cruise on the highway. I'm seeing head temps settling around 360 with up to 385 (IMG:style_emoticons/default/unsure.gif) on long uphill sections, and oil temps of about 230. Around town temps hang out at about 345 and 225.
Thanks in advance for the advice! This forum is a really great resource.
thenewwazoo   ATL area type IV megasquirt tuners?   Feb 20 2010, 09:37 PM
kg6dxn   Are you running a MAP sensor? it sounds like you m...   Feb 20 2010, 10:07 PM
thenewwazoo   Are you running a MAP sensor? it sounds like you ...   Feb 20 2010, 10:10 PM
brer   hey, would be at all interested in sharing some 9...   Feb 20 2010, 10:47 PM
underthetire   hey, would be at all interested in sharing some ...   Feb 20 2010, 10:52 PM
904svo   I live in wodstock am I still trying to get my Meg...   Feb 21 2010, 08:31 AM
McMark   I'm a huge proponent of crank triggering for M...   Feb 21 2010, 10:37 AM
underthetire   I'm a huge proponent of crank triggering for ...   Feb 21 2010, 10:45 AM
thenewwazoo   That may be, but you're also selling something...   Feb 21 2010, 10:40 AM
McMark   :agree: for fuel only, you can get away with coil ...   Feb 21 2010, 11:48 AM
underthetire   :agree: for fuel only, you can get away with coil...   Feb 21 2010, 12:08 PM
thenewwazoo   ... especially at low RPM and idle. Okay, well,...   Feb 21 2010, 05:22 PM
DBCooper   :agree: for fuel only, you can get away with coil...   Feb 21 2010, 05:32 PM
904svo   I'm running Megasquirt with a 36-1 tooth wheel...   Feb 21 2010, 04:10 PM
underthetire   I'm running Megasquirt with a 36-1 tooth whee...   Feb 21 2010, 04:35 PM
904svo   I'm running Megasquirt with a 36-1 tooth whe...   Feb 21 2010, 05:20 PM
underthetire   [quote name='underthetire' post='1276811' date='F...   Feb 21 2010, 05:24 PM
John Jentz   I'm running Megasquirt with a 36-1 tooth whe...   Feb 21 2010, 05:42 PM
BIGKAT_83   Should be no trouble finding someone in Atlanta to...   Feb 21 2010, 05:46 PM
904svo   My (fairly new-to-me) megasquirted '74 2L is ...   Feb 21 2010, 08:58 PM
thenewwazoo   Type 4 like to run about 13:1 to stay cool at tho...   Feb 21 2010, 09:25 PM
kg6dxn   try this link http://914megasquirt.ning.com/   Feb 21 2010, 10:09 PM
brer   try this link http://914megasquirt.ning.com/ y...   Feb 22 2010, 12:37 PM
Jake Raby   I'm no fan of MS, but I'd be happy to assi...   Feb 21 2010, 10:28 PM
thenewwazoo   I'm no fan of MS, but I'd be happy to ass...   Feb 22 2010, 01:01 PM
Al Meredith   I think in your first post you said you were runni...   Feb 22 2010, 12:52 PM
thenewwazoo   I think in your first post you said you were runn...   Feb 22 2010, 01:05 PM
toon1   My (fairly new-to-me) megasquirted '74 2L is ...   Feb 22 2010, 06:41 PM
Jake Raby   I agree.. Over-advancing is pretty easy to do, esp...   Feb 23 2010, 02:22 PM
underthetire   While I agree with both of you, 36 is too much, it...   Feb 23 2010, 02:35 PM
thenewwazoo   Cool - I've got an appointment with Dean @ Rab...   Feb 23 2010, 02:56 PM
Jake Raby   . We'll see you then. Have the engine tuned...   Feb 23 2010, 03:29 PM
904svo   Jake, are on lookers allowed to watch?   Feb 23 2010, 04:01 PM
Jake Raby   Jake, are on lookers allowed to watch? [u][size...   Feb 23 2010, 04:16 PM
thenewwazoo   Man, that was great! Jake let me invite all my...   Mar 17 2010, 02:07 PM
Jake Raby   Glad to see the car is better than it was when you...   Mar 17 2010, 03:25 PM
JamesM   Did the tuning help with the head temps? Also, wh...   Mar 17 2010, 07:21 PM
thenewwazoo   Did the tuning help with the head temps? Also, w...   Mar 17 2010, 08:57 PM
904svo   If you are using a FI cam, you may have to rebuild...   Mar 17 2010, 08:05 PM
thenewwazoo   If you are using a FI cam, you may have to rebuil...   Mar 17 2010, 08:58 PM
904svo   If you are using a FI cam, you may have to rebui...   Mar 17 2010, 09:22 PM
thenewwazoo   The tables are 12X12 or 8x8. If you don't use...   Mar 17 2010, 09:26 PM
904svo   [quote name='904svo' post='1288347' date='Mar 17 ...   Mar 17 2010, 09:45 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 09:47 AM
