Cooling Fans, Early / Late 1.7 and 2.0 A Comparison. |
Sleepin |
Feb 21 2010, 08:28 PM
Advanced Member Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains |
I had a question: Can I use this late 2.0 fan on my early 1.7? A search didn't yield much, and most of the responses I got was "I dunno, it should work".
Well here is what I found: I had an early 1.7 that was missing way to many fan blades for me to want to use: (IMG:http://i171.photobucket.com/albums/u307/Sleepin1974/Dads%20914/108_0090.jpg) Here is the front of the early fan and the factory screw (note: this uses the same wrench as the factory CV bolts do): (IMG:http://i171.photobucket.com/albums/u307/Sleepin1974/Dads%20914/108_0085.jpg) The early fan and factory bolt has an 11mm contact surface once it exits the fan: (IMG:http://i171.photobucket.com/albums/u307/Sleepin1974/Dads%20914/108_0086.jpg) I wanted to measure the depth as well, just to be sure. 20mm: (IMG:http://i171.photobucket.com/albums/u307/Sleepin1974/Dads%20914/108_0087.jpg) The only other measurement I could think of was this one: (IMG:http://i171.photobucket.com/albums/u307/Sleepin1974/Dads%20914/108_0095.jpg) |
Sleepin |
Feb 21 2010, 08:44 PM
Now the late (1976) 2.0 Fan (note this has a hub for spinning the air pump):
(IMG:http://i171.photobucket.com/albums/u307/Sleepin1974/Dads%20914/108_0089.jpg) A longer bolt on the late model than was on the early model, but still a 11mm contact surface: (IMG:http://i171.photobucket.com/albums/u307/Sleepin1974/Dads%20914/108_0094.jpg) The same 20mm depth: (IMG:http://i171.photobucket.com/albums/u307/Sleepin1974/Dads%20914/108_0092.jpg) And the same "backspacing": (IMG:http://i171.photobucket.com/albums/u307/Sleepin1974/Dads%20914/108_0097.jpg) Now I printed off the Pelican timing mark template: (IMG:http://i171.photobucket.com/albums/u307/Sleepin1974/Dads%20914/108_0108.jpg) Here is where I did have a question...this is the early 1.7L fan, and it does not match up with the Pelican template. Does anyone have the answer? (IMG:http://i171.photobucket.com/albums/u307/Sleepin1974/Dads%20914/108_0103.jpg) I have learned that you just need to watch for the bolt length. If the bolt is too short, you will not have sufficent contact area to hold the fan on. If you have too long of a bolt (say a late bolt in an early fan) you will wipe out the oil seal on your block. Using the bolts that come with the fan work well between the engines, given an 11mm contact area outside of the fan. If you need to restamp the timing marks with the Pelican template, just make sure you are printing it at 100% and not 110%. (IMG:style_emoticons/default/wink.gif) If you think that four blades are not reason enough to seek out a replacement fan, just do the math. 31 blades, 3 missing = 10% loss of cooling efficiency. Just something to think about and dont turn the engine over with a screwdriver on the blades! |
Katmanken |
Feb 21 2010, 10:02 PM
You didn't even mention the balance issue with the missing blades...
Nothing like adding an unbalanced load to a crank shaft that can spin over 5K (IMG:style_emoticons/default/blink.gif) |
Sleepin |
Feb 21 2010, 10:05 PM
(IMG:style_emoticons/default/agree.gif) I figured it was a given. (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/biggrin.gif)
McMark |
Feb 21 2010, 10:11 PM
Here's one thing to note right off the bat, although it's minor, the '0' is TDC and the red notch is 27*.
Also, I'm not sure if early T4 bus or 411 motors came with that 'early' style fan. Those motors, at least the bus ones, didn't read the timing through the hole in the fan housing, so they are marked differently. So, while I'm not sure, you could have an early bus fan and not an early 914 fan. Can you still read the part number on the early fan? It would be stamped in blue ink on the inside surface of the fan. |
McMark |
Feb 21 2010, 10:15 PM
Try this, lie both fans 'upside down' on your work bench and clock them both so the crank alignment pin is in the same location. Then transfer the timing mark locations to the back face. I bet your early fan just doesn't have a TDC marking and the red notch is still at 27*.
Sleepin |
Feb 21 2010, 11:03 PM
Try this, lie both fans 'upside down' on your work bench and clock them both so the crank alignment pin is in the same location. Then transfer the timing mark locations to the back face. I bet your early fan just doesn't have a TDC marking and the red notch is still at 27*. I did this Mark, just by laying the two fans on top of each other and eyeballing them, it appears that there is not a TDC mark. Not sure what the mark on the early fan is though. (IMG:http://i171.photobucket.com/albums/u307/Sleepin1974/Dads%20914/108_0113.jpg) |
Sleepin |
Feb 21 2010, 11:12 PM
Here is the back of the early fan:
(IMG:http://i171.photobucket.com/albums/u307/Sleepin1974/Dads%20914/108_0102.jpg) Here is the back of the 1976 fan: (IMG:http://i171.photobucket.com/albums/u307/Sleepin1974/Dads%20914/108_0107.jpg) |
sixnotfour |
Feb 22 2010, 12:38 AM
914 Wizard Group: Members Posts: 10,432 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
1.7 litre engine They are 5 degrees before TDC (static timing mark) and 27 degrees before TDC (dynamic timing mark).
Sleepin |
Feb 22 2010, 12:54 AM
Makes total sense! Thanks Jeff!
Cap'n Krusty |
Feb 22 2010, 09:27 AM
Nevermind. Sleep fogged my brain ......... The Cap'n
TheCabinetmaker |
Feb 22 2010, 09:43 AM
Is he not viewing the fan from the rear?
Sleepin |
Feb 22 2010, 10:49 AM
Here is a pic of the early bolts on the late fan. Notice the 4.5mm contact area (ie. Don't do this):
(IMG:http://i171.photobucket.com/albums/u307/Sleepin1974/Dads%20914/108_0091.jpg) |
McMark |
Feb 22 2010, 12:19 PM
Eric, is it coincidence that your login is Sleepin' and that last picture looks like eyelids closing? (IMG:style_emoticons/default/idea.gif)
Sleepin |
Feb 22 2010, 12:26 PM
No, that was a "it is so cold the camera shutter wouldn't open all the way" pic! (IMG:style_emoticons/default/lol-2.gif)
Lo-Fi Version | Time is now: 19th May 2024 - 03:50 PM |
