Length of window crank on a 914 |
75boxster |
Mar 26 2004, 07:33 AM
Member Group: Members Posts: 89 Joined: 1-January 04 From: Ft. Collins, CO Member No.: 1,488 |
I was hoping someone would measure their window crank from
the mounting screw to the end. I'm not being lazy, I have electric windows now and want to convert back to cranks. There is a tweeter mounted close enough that I thought I should see if that was going to be in the way. Thanks for any help. |
VegasRacer |
Mar 26 2004, 12:00 PM
ELVIRA Group: Benefactors Posts: 8,507 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None |
Does this help?
Mark Henry |
Mar 26 2004, 12:22 PM
The cranks are standard Beetle units.
75boxster |
Mar 28 2004, 07:56 PM
Thank you very much. Turns out the tweeter need to be moved. Dagnabbit!
Lo-Fi Version | Time is now: 13th May 2024 - 08:10 PM |
