| 914werke |
Feb 25 2010, 06:11 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,683 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
Jonathan so the round retaining elements are Bearings not just the OE cups for rubber (or other) style bushings? Can they be removed / rebuilt? Purchased separately? same with the arms can they be purchesed w/o links?
I guess the related question is what is the dimension of the (square) mounting ends? Last question ...how much does it weigh? |
| siverson |
Feb 25 2010, 08:23 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,464 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California
> I have a very early Tarett bar and otherwise like it. I added my own markings because i use the bar often and without markings setting both sides equal is more guesswork than anything ...
Markings seem like a good idea to write settings down, but I don't think it matters if the sides are exactly even. Left/right cornering will be the same and the effective rate is just somewhere in between the "long" and "short" arm. Let me know if I'm wrong though... -Steve |
| SirAndy |
Feb 25 2010, 09:43 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,483 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Let me know if I'm wrong though... You are correct as long as you don't want to set the bar by numbers. For example, the Smart Racing bars come with charts that let you look-up the exact amount of stiffness per bar-size and position of the drop-link on the arm. Plus, different size bars have overlapping settings. While i usually just go by feeling, it's sometimes good to be able to refer to the charts. The charts expect both sides to be set equal. I know this is probably not your typical use, but on the 911 racecar we even sometimes swap swaybars inbetween run sessions and it's crucial to be able to know exactly where they overlap in order to set them correctly for the next session. (IMG:style_emoticons/default/shades.gif) Andy |
| Chris Hamilton |
Feb 25 2010, 10:00 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 611 Joined: 7-March 06 From: Berkeley, CA Member No.: 5,687 |
So the $475 GPR bar is just the bar and bushings, or the whole kit with arms and droplinks?
| sww914 |
Feb 25 2010, 10:02 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None |
I have one of these at my shop right now and it is very, very nice. It's about time we had some adjustable ends to fit a stock bar. I've wanted one for years.
| sean_v8_914 |
Feb 26 2010, 08:56 AM
Chingon 601 ![]() ![]() ![]() ![]() Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 |
markings, YES! we have a Tarret bar on the 10jereen. we do change settings frequently also. lets all pester Ira till he adds them.the nice thing about a GPR vs Tarrett is that the GPR is better suited for general 914 use while Tarett bar is good for more extreme performance minded 914s
splines? why do you believe splines to be of benefit? |
| hwgunner |
Feb 26 2010, 09:39 AM
914 Parts @ Discount Prices 800.321.5432 ![]() ![]() ![]() Group: Members Posts: 1,714 Joined: 11-November 04 From: Santa Maria, Ca Member No.: 3,095 Region Association: None |
So the $475 GPR bar is just the bar and bushings, or the whole kit with arms and droplinks? The whole kit; Bar, Arms and Drop Links is $475. If you want just the bar and want to use your stock arms and droplinks it is $250 and if you want just the arms and links to use on your stock bar it is $250. |
| PeeGreen 914 |
Feb 26 2010, 11:27 AM
Just when you think you're done...wait, there is more..lol ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest
Nice Jonathan (IMG:style_emoticons/default/aktion035.gif)
Still have my big Tarret I bought from you (IMG:style_emoticons/default/beerchug.gif) |
| hwgunner |
Feb 26 2010, 11:36 AM
Jonathan so the round retaining elements are Bearings not just the OE cups for rubber (or other) style bushings? Can they be removed / rebuilt? Purchased separately? same with the arms can they be purchesed w/o links? I guess the related question is what is the dimension of the (square) mounting ends? Last question ...how much does it weigh? The round retaining elements are called 'bearing blocks' and house a thermo plastic teflon impregnated 'bushing' that takes the place of the stock rubber type. the bearing blocks and bushings can be removed and "rebuilt" but based on past performance in the Tarett bars i will guarentee the bushings for life. They just wont wear out. The arms could be purchased with out the drop links for special projects but that said, the arms are not compatible with the stock drop links. You need a drop link with a spherical rod end to use with the arms. The square on the arms is 19mmx19mm. This is the same size as the Tarett Bar but mine comes with spacers to bring the size down to just under 17mmx17mm, or the size of a stock sway bar end. As to the weight question, the complete bar with arms and drop links weighs just under 7lbs. The bar alone weighs 2.68lbs compared to 3.12lbs for a stock 914 bar and 6.46lbs for the Weltmeister solid 19mm bar. The front arms and drop links complete with hardware weigh just 2.5lbs. I think that covers it but let me know if there are any other questions. |
| mtn flyr |
Feb 26 2010, 01:59 PM
Member ![]() ![]() Group: Members Posts: 235 Joined: 20-December 07 From: Bozeman Mt Member No.: 8,491 Region Association: Rocky Mountains
Are these in stock at this time?
| hwgunner |
Feb 26 2010, 02:01 PM
| BigD9146gt |
Feb 26 2010, 02:14 PM
OCD member ![]() ![]() Group: Members Posts: 376 Joined: 24-January 05 From: Sydney, Australia Member No.: 3,502 Region Association: Australia and New Zealand |
New GPRBar SWAY BAR Kinda Cool, I Think
WAY TO GO JOHATHAN! I love the upsell and confidence too! (IMG:style_emoticons/default/stirthepot.gif) But on a serious note, very nice! (IMG:style_emoticons/default/aktion035.gif) |
| mtn flyr |
Feb 27 2010, 08:35 PM
I'll be in touch soon, and here is a (IMG:style_emoticons/default/icon_bump.gif) for ya
| campbellcj |
Feb 28 2010, 10:58 AM
I can't Re Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,714 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California
If somebody made a REAR 914 swaybar with better quality hardware and improved geometry vs. the Weltmeister, I would definitely be interested.
I know it is a very small market since you can't cross-sell to the 911 guys so it's unlikely we will ever see this, but wishful thinking never hurts. |
| markb |
Mar 3 2010, 07:15 PM
914less :( ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,450 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California
(IMG:style_emoticons/default/icon_bump.gif) I spent all day putting together the kits for these. This is really cool stuff!
| nsr-jamie |
Nov 6 2010, 02:41 AM
914 guy in Japan ![]() ![]() ![]() Group: Members Posts: 1,182 Joined: 7-November 07 From: Nagoya, Japan Member No.: 8,305 Region Association: None |
Hi, I know this is an older thread, I am very interested in this front sway bar. Are they for sale still and also will they come with the markings like people are asking for. How do I go about ordering one?
Thank you |
| tradisrad |
Nov 8 2010, 04:30 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California |
I got my GPRBar in the mail today and it looks great. I hope to install it tomorrow (maybe this evening).
I've got a question. What are the 4 shims for? |
| hwgunner |
Nov 8 2010, 05:33 PM
I got my GPRBar in the mail today and it looks great. I hope to install it tomorrow (maybe this evening). I've got a question. What are the 4 shims for? They go between the bar end and the arm to make the fit snug. The shims should be on adjoining sides not opposite sides. if you have any questions let me know. Jonathan 800-321-5432 |
| EdwardBlume |
Nov 8 2010, 05:56 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,340 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California
I picked the one up that was in the classifieds.... it sure will look nice on Dad's car... (IMG:style_emoticons/default/aktion035.gif)
| NC_Colfax |
Nov 8 2010, 05:57 PM
Member ![]() ![]() Group: Members Posts: 130 Joined: 26-July 10 From: North Carolina Member No.: 11,982 Region Association: South East States |
Looks like a very well made product
Lo-Fi Version | Time is now: 24th June 2026 - 02:01 PM |
