| tradisrad |
Nov 8 2010, 05:59 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California |
I picked the one up that was in the classifieds.... it sure will look nice on Dad's car... (IMG:style_emoticons/default/aktion035.gif) I was going to buy the one from Casey944, but a friend lured me into a 22mm (price was right) and I was not happy with the 22. So I will go and install this bar in the next few days (hopefully tonight) and I'll report back. I'll take some picture too. |
| Eric_Shea |
Nov 8 2010, 06:01 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Sounds like you're doing the right thing. (IMG:style_emoticons/default/smilie_pokal.gif)
If you get the arms with it, set them full soft and start bringing them in until you've dialed in the comfort level you're happy with. Good luck. |
| SirAndy |
Nov 8 2010, 06:10 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,483 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
If you get the arms with it, set them full soft and start bringing them in until you've dialed in the comfort level you're happy with. (IMG:style_emoticons/default/agree.gif) For a new install, always start by setting the bar to FULL This is by far the safer approach! (IMG:style_emoticons/default/popcorn[1].gif) EDIT: Modified for correct orientation ... |
| EdwardBlume |
Nov 8 2010, 06:19 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,340 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California
I picked the one up that was in the classifieds.... it sure will look nice on Dad's car... (IMG:style_emoticons/default/aktion035.gif) I was going to buy the one from Casey944, but a friend lured me into a 22mm (price was right) and I was not happy with the 22. So I will go and install this bar in the next few days (hopefully tonight) and I'll report back. I'll take some picture too. I need to install the bar into a car that has never had a sway bar... or should I say, Mark is going to install the bar... etc... |
| tradisrad |
Nov 9 2010, 08:55 AM
The New GPRBar is installed. I took it for a short test drive and it really seems to be what I was looking for as far as performance.
The install was straght forward and from start to completion of test drive I spent about 2 hours. Probably the most challening part was getting the bar through the second mount. I found that I had to loosen the mounts and I was able to get the bar through w/o much trouble. Comparison of sway bars. 22mm Weltmeister w/factory arms; stock bar; GPRBar. ![]() Factory arm length compared to GPRBar ![]() Installed pic ![]() installed pic; looks like I need to clean some more grime from the wheel wells ![]() Installed pic. Pass side ![]() one more ![]() |
| DanT |
Nov 9 2010, 09:17 AM
Going back to the Dark Side! ![]() ![]() ![]() ![]() Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
with the longer arm set at full soft, you are probably at the same spring rate as the stock bar (IMG:style_emoticons/default/biggrin.gif)
Looks good Rob....those are nice looking bars that GPR puts out. |
| tradisrad |
Nov 9 2010, 09:51 AM
with the longer arm set at full soft, you are probably at the same spring rate as the stock bar (IMG:style_emoticons/default/biggrin.gif) Looks good Rob....those are nice looking bars that GPR puts out. It sure feels better than the stock bar. I am not getting the lifting in the rear on freeway on ramps like I was getting with the stock bar & I am and not getting the flat dive into the corners (with the 22mm bar) nor do I feel any oversteer. So, how do I know what setting of the bar will give me a true 19mm bar spring rate. I assumed that setting the drop link at the end of the arm it would give me the spring rate of 19mm. What will the spring rate increase to as the drop link moves closer to the bar? Can we make or get a chart to help define the setting? thanks -Rob |
| Eric_Shea |
Nov 9 2010, 09:52 AM
QUOTE with the longer arm set at full soft, you are probably at the same spring rate as the stock bar Just for the fun of it... I'm going to (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/biggrin.gif) That's exactly what I would do. Full soft and then if you needed more for an auto-x event, slide them around a bit and play with the rate. |
| SirAndy |
Nov 9 2010, 01:26 PM
So, how do I know what setting of the bar will give me a true 19mm bar spring rate. I assumed that setting the drop link at the end of the arm it would give me the spring rate of 19mm. What will the spring rate increase to as the drop link moves closer to the bar? Can we make or get a chart to help define the setting? I don't think that's what you should be looking for. Trying to set a bar "by numbers" for a initial setup is asking for trouble. Start with the bar set to full No two cars will have/need the same settings. You need to forget about numbers and dial in the bar to where your car handles the best according to your personal preference. Just a word of advice. DO NOT attempt to dial in a bar on public roads. If you overshoot the settings you can end up with severe oversteer which will result in the car switching ends during high speed cornering!!! Do your setup testing in a large empty parking lot away from anything you can hit. I usually use one of the local AX venues to do some fine tuning. All you can hit there are plastic cones. (IMG:style_emoticons/default/popcorn[1].gif) EDIT: Modified for correct orientation ... |
| ChrisFoley |
Nov 9 2010, 08:50 PM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,031 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
| SirAndy |
Nov 9 2010, 09:58 PM
I think you've got that backwards Andy. soft front bar = oversteer Baaaah ... Why do i always reverse the two? Go figure ... Chris is right, it's the other way round ... If the rear is lose, tighten the front. (IMG:style_emoticons/default/rolleyes.gif) |
Lo-Fi Version | Time is now: 24th June 2026 - 02:00 PM |
