Brake pressure regulator |
watsonrx13 |
Mar 5 2010, 05:29 PM
Advanced Member Group: Members Posts: 2,734 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
Eric's ad selling the 912 rear calipers started a discussion about the brake pressure regulator. I'd like to continue that discussion. Eric mentions that he wouldn't replace the regulator with a 'T' fitting. What I would like to know is how could you test the regulator off of the car? At $300 - $400 a piece from the dealer I would like to test mine before I purchase a new one.
Also, Eric mentioned that the front calipers shouldn't be used on the rear, even with the regulator. Is there any problem installing a set of rebuilt rears on and not installing the parking brake cables? Any thoughts and suggestions are welcomed. BTW, I'd like to keep this discussion only for the 4-lug wheels. Also, what are the thoughts about replacing the master cylinder with the larger one how does that effect the brake biasing? -- Rob |
SirAndy |
Mar 5 2010, 05:36 PM
Resident German Group: Admin Posts: 41,650 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Stock brakes and a "T" is a bad idea that will get you and your car hurt in no time ...
Why do you want to replace your Prop Valve? I have never seen one go bad, what's wrong with yours? (IMG:style_emoticons/default/popcorn[1].gif) Andy |
type47 |
Mar 5 2010, 05:41 PM
... and why would you want to mount rebuilt rear brake calipers and not connect the parking brake cables?
Tom_T |
Mar 5 2010, 05:51 PM
(IMG:style_emoticons/default/idea.gif) .... hmmmm ..... well - just a guess here - but if you don't connect the cables & park on a hill - then it might just roll away IMHO! (IMG:style_emoticons/default/laugh.gif)
I've also heard that the proportioning valves rarely if ever fail! (IMG:style_emoticons/default/confused24.gif) So why - as per Andy???? |
watsonrx13 |
Mar 5 2010, 06:01 PM
I'm not advocating replacing the pressure regulator just trying to bring the discussion to the garage so that it can be research for future references. I have several cars that have the brake systems open (calipers removed) and was wondering if there is a possibility that this could effect the internal workings of the regulator.
I've seen discussions about mounting the front calipers on the rear but never understood the reasoning, which would mean that the hand brake cables wouldn't be connected. -- Rob |
watsonrx13 |
Mar 5 2010, 06:02 PM
(IMG:style_emoticons/default/idea.gif) .... hmmmm ..... well - just a guess here - but if you don't connect the cables & park on a hill - then it might just roll away IMHO! (IMG:style_emoticons/default/laugh.gif) Hill, I live in FL there are no hills... (IMG:style_emoticons/default/lol-2.gif) -- Rob |
Tom_T |
Mar 5 2010, 06:07 PM
(IMG:style_emoticons/default/idea.gif) .... hmmmm ..... well - just a guess here - but if you don't connect the cables & park on a hill - then it might just roll away IMHO! (IMG:style_emoticons/default/laugh.gif) Hill, I live in FL there are no hills... (IMG:style_emoticons/default/lol-2.gif) -- Rob Well there are in the FL panhandle where my sister lives! ... more like hummocks to the rest of the world! (IMG:style_emoticons/default/lol-2.gif) ... Okay then - so it could roll off the road, down the drainage swale & into the swamp & give a `Gator indigestion - then you'll have EPA & the Enviro's all over your case! (IMG:style_emoticons/default/av-943.gif) Cheers! (IMG:style_emoticons/default/beerchug.gif) -- Tom |
McMark |
Mar 5 2010, 07:10 PM
The E in E-Brake stands for EMERGENCY. Emergencies are unplanned situations, so you can't plan for them. You should have working emergency brakes in case you find yourself in an emergency. I can never wrap my head around how people can be so cavalier about disabling one of the most fundamental safety features. While you're at it, take out your seat belts since you don't plan to have any accidents. (IMG:style_emoticons/default/rolleyes.gif)
RANT OVER! (IMG:style_emoticons/default/cool.gif) |
SirAndy |
Mar 5 2010, 07:28 PM
Mike Bellis |
Mar 5 2010, 07:40 PM
I could see replacing it with an adjustable one.
Problably would not really be needed for a mid engine cars front to rear weight ratio unless it was a full race vehicle. |
Eric_Shea |
Mar 5 2010, 07:44 PM
I can't type all that crap again so I'll just paste it here: (IMG:style_emoticons/default/smile.gif)
QUOTE You can also bias brakes with pad compound. ie: stickier pads up front and not so sticky in the rear... That's not a great idea. It takes a LOT of hit or miss and experience with pad compounds to play this game. Dan is the only guy I know that has done this successfully and he races his 914 regularly in wheel to wheel competition. Do me (yourself) a favor, make a quick list of all the brake pads you know of for our 914's. Now list them, in order, from stickier to not so sticky. Ready... go! (IMG:style_emoticons/default/wink.gif) The question is; why? When the proper caliper with the proper piston size for best biasing, made off the same casting, with the same pad size is available to bolt on to the same mounting location; why put an irregularly large pistoned caliper back there? QUOTE With any or all of the calaper combinations you discussed....do any of the combinations ALLOW the removal of the stock... brake bias/brake pressure requlator?...or do to a specific combination,is the B.B. P.requlator... removed to achieve maximum breaking ability? Not on my car. Removing it does not acheive maximum braking ability. The pressure regulator is SO WAY MISUNDERSTOOD by the 914 crowd. One day, back when we were smashing rocks together for fire sparks, someone said; "If you take the proportioning valve out you'll have better brakes." I bought into it for a while as well, until I did some further reading. There's a page dedicated to it in the factory manual and it's a great read. The funny thing is, the Alfa boys have the exact same valve and if you cruise posts on their board regarding the subject, they would think you were crazy if you wanted to take this out. That said; the pressure regulator is not a proportioning valve or a bias valve of any sort so it stands to reason it has a purpose beyond balancing our braking bias (which the factory did extremely well with piston sizes... hence the chatting herein). There are two things that you should read to help you put this together in your own mind. They helped make it click for me and I've never gone back to recommending a "T" fitting or an aftermarket bias valve to anyone ever again. Those two things are: 1. Vic Elfords book on Porsche Handling. There's a section about "mid-Engine" and it touches on 914's. We get all pumped up when we tell others our cars are "mid-engine" and superior to God in handling. Vic points out that they are rather good but, the 924-944-968 package is better because, polar moment inertia can cause our little 914's to spin like a top once they get started. Having the weight at the ends (engine in front, tranny in the rear) is much more predictable and controllable. It's a good book to have and a great read when learning all that you can about your Porsche. 2. The page from the manual explaining what this little bugger really is. As stated before, it's not a proportioning valve or a bias control. It (as you rightfully stated) regulates pressure. It ONLY does this when it experiences a panic stop of 535lbs. of line pressure. It shuts the rear circuit down and slowly brings it back in to prevent the rear wheels from locking up. This keeps as much control as possible in the rear of the car in such an instance (no screaching, locked up tires back there). Bottom line; the pressure regulator sits there and acts just like a "T" fitting, passing all the fluid you can deliver to the rear calipers unless there's an emergency where they may lock up. Then it springs into action. The only problem is, it sucks to bleed. But it sucks even harder if you're the one bleeding. I hope that helps someone. ****************************************************** Now to try to help with your questions: They rarely go bad HOWEVER, In an open system I see Master Cylinders go 30-40% of the time. I can only attribute that to the rubber seals seeing fresh air for the first time in a long time. My "guess" is they crack and it's new MC time. This happens too often to my clients doing a full brake job to ignore it. The reason I mention Master Cylinders is, the seals look identical and may be. I could do some research but, the Alfa guys have a kit I believe. QUOTE what are the thoughts about replacing the master cylinder with the larger one how does that effect the brake biasing? Go for it. There's way too much internet chatter on this and the affect will be negligable. No, it doesn't affect the bias, just the overall pressure in the system. The benifit will be a firmer pedal feel and a less expensive Master Cylinder. The downside is, the pedal is harder to push down. It is only SLIGHT and after about 10 minutes behind the wheel you'll get use to it. This is why I say there's too much chatter going on. When it comes time, everyone should just move to a 19mm and be done with it. That's my $0.08 (adjusted for inflation and devalued for overall worth). |
watsonrx13 |
Mar 5 2010, 07:51 PM
Thanks Eric for the update.
-- Rob |
Tom_T |
Mar 5 2010, 07:54 PM
Actually it is BOTH !!!! If the hydraulics fail in the primary system, then the mechanically actuated rear brakes can be used in an EMERGENCY to stop the vehicle, as well as to hold it in place while PARKED on level or sloped ground! Now play nice Boyz! (IMG:style_emoticons/default/grouphug.gif) |
Eric_Shea |
Also... disconnecting hand brake cables would have nothing to do with the overall effectiveness of the braking system. They are part of a manual system that lives in a hydraulic world.
Handbrakes work best when the cables are hooked up ( (IMG:style_emoticons/default/tongue.gif) ) and the venting clearance is set properly. |
Eric_Shea |
Mar 5 2010, 07:58 PM
watsonrx13 |
Mar 5 2010, 08:08 PM
Thanks Eric, very good description.
BTW, is there any way to 'bench bleed' the pressure regulator to get the air out? Or just pump, bleed, repeat until firm? -- Rob |
Tom_T |
Mar 5 2010, 08:09 PM
Great dissertation from the Guru of Porsche Brakes (Eric) !!!!
... cleared up a lot of things for me too Eric! (IMG:style_emoticons/default/smile.gif) BTW Rob - for what it's worth based upon Eric's & others' on here advice - I got the ATE 19mm 914-6 MC for my 73 2L too (1/2 the price of 17mm), to swap out from my OE 17mm one, since it's been sitting on blocks in my garage since 5/85 & probably in need of rebuilding anyway. So that - combined with an Eric set of F&R Calipers, Porterfield R4S's, new OEM hoses, etc. should give me a better performing and more reliable braking system on mine when done, which still passes as original if I ever want to do CW insanity! (IMG:style_emoticons/default/smile.gif) ... oh & NEW E/P-brake cables actually hooked up to boot! (IMG:style_emoticons/default/biggrin.gif) That's my -$0.08 worth - since I'm far less a guru in this than Eric! (IMG:style_emoticons/default/laugh.gif) |
ConeDodger |
Mar 5 2010, 09:15 PM
Apex killer! Group: Members Posts: 23,594 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Funny you should say that. I just had a conversation with a paramedic student from Northern Ireland yesterday who failed his drivers test because the examiner told him to set the emergency brake and he didn't know what she was talking about. By the time he figured out she was talking about the parking brake, she was walking away... (IMG:style_emoticons/default/mad.gif) Ahhh... Cultural cognition. We supposedly speak the same damned language. |
campbellcj |
Mar 5 2010, 10:48 PM
I can't Re Member Group: Members Posts: 4,545 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
Here is the original thread over in the classifieds:
http://www.914world.com/bbs2/index.php?sho...p;#entry1283017 |
pbanders |
Mar 5 2010, 11:00 PM
Senior Member Group: Members Posts: 939 Joined: 11-June 03 From: Phoenix, AZ Member No.: 805 |
Good stuff. FWIW, the "in car" test I was taught for the proportioning valve is that while sitting still with the motor off (even better in a quiet garage), press hard on the brake pedal, and slowly release. If the proportioning valve is working correctly, as you release the pedal, you'll hear the valve go "boing" as the internal pressure drops below the onset threshold.
From the pressures involved, I suspect a "bench setup" to test the valve would be challenging. |
Lo-Fi Version | Time is now: 20th May 2024 - 12:54 PM |
