WTB, Passenger Rear Outer Suspension Console |
Ericv1 |
Mar 7 2010, 08:55 AM
Member Group: Members Posts: 259 Joined: 30-December 07 From: Cincinnati, Ohio Member No.: 8,518 Region Association: Upper MidWest |
This holds the control arm I believe with three bolts. It appears to be spot welded and seam welded at the bottom. Mines in bad shape and needs to be replaced. Please send a PM if you have one you can cut off a parts car. Thanks, Eric |
Ericv1 |
Mar 7 2010, 09:38 AM
Lennies914 |
Mar 7 2010, 09:47 AM
Slacker Group: Members Posts: 828 Joined: 9-January 10 From: NorCal Member No.: 11,216 Region Association: Northern California |
I've got the donor car and that piece looks good. It looks like I'd need to cut the fender for access? I assume you just need the top half? Make me an offer.
Lennie |
Ericv1 |
Mar 7 2010, 09:52 AM
I've got the donor car and that piece looks good. It looks like I'd need to cut the fender for access? I assume you just need the top half? Make me an offer. Lennie I was told you could drill it out with a 90 degree attachment on a drill without cutting the fender. |
914werke |
Mar 7 2010, 10:27 AM
"I got blisters on me fingers" Group: Members Posts: 10,057 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Lo-Fi Version | Time is now: 11th May 2024 - 03:51 PM |
