| plymouth37 |
Mar 10 2010, 02:12 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,825 Joined: 24-May 05 From: Snoqualmie, WA Member No.: 4,138 Region Association: Pacific Northwest
Are you still in school? If you are you should grab a copy of SolidWorks and model what you are building. Then you can use the integrated FEA software to mess with tube sizes. Its quite easy to use (and there are some great tutorials about building tube frames in it on Youtube), and would really help you out with choosing tube size. (IMG:style_emoticons/default/smile.gif) That is actually a really good idea, the formula sae teams use solidworks to analyze their frames so I should be able to find a computer in the engineering building that has it on it. Solidworks also offers a student edition for $100 ($2900 less than retail). |
| WRX914 |
Mar 11 2010, 09:17 AM
2.5 WRX STI hybrid powered beast ![]() ![]() ![]() Group: Members Posts: 782 Joined: 16-September 04 From: Las Vegas, NV Member No.: 2,771 Region Association: Southwest Region |
Ohhh to have the time to entertain these things!!!
Dana, How's my old rommie doin? How is Becky? How is Laurie? Hope all is well. |
| jd74914 |
Mar 11 2010, 09:34 AM
Its alive ![]() ![]() ![]() ![]() Group: Members Posts: 4,864 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
That is actually a really good idea, the formula sae teams use solidworks to analyze their frames so I should be able to find a computer in the engineering building that has it on it. Solidworks also offers a student edition for $100 ($2900 less than retail). Yep, I've used it on a few frames. The beam analysis feature works really well. |
| plymouth37 |
Mar 11 2010, 09:58 AM
Ohhh to have the time to entertain these things!!! Dana, How's my old rommie doin? How is Becky? How is Laurie? Hope all is well. Plugging away at my architecture degree and looking at grad school, Beckie and my mom are doing well. We have a little house and a couple dogs, Life is good! |
| YksKrad |
Mar 14 2010, 01:47 AM
Member ![]() ![]() Group: Members Posts: 72 Joined: 14-February 05 From: Rolla, MO Member No.: 3,602 Region Association: Upper MidWest |
I'm not too good with this kind of stuff, but as far as solid works goes they have a nice set of tutorials on youtube http://www.youtube.com/user/solidworks... I believe they explicitly cover frame design in the tutorials. The FSAE team I'm on uses NX for frame design, I'm not sure what is used to analyze it though....
As I said I'm not very good at this, but squares are bad, triangles are good. These two seem to jump out at me. ![]() Sorry, but I can't give you much better advice. I haven't really been involved in that aspect of our car's design... |
| Rand |
Mar 14 2010, 10:46 PM
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,413 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
My Qs are in blue. You already have the crosses to the tranny points done so those are redundant for this conversation.
Inside the blue circle... Why would you go up there? To me, the strong point to tie into is the tip of the blue arrow as that's what ties forward. I would ignore anything above it. So top of shock tower forward to that point (my blue bar) is the strongest and most important piece in my mind. Outer suspension point is strong by default. Inner ear needs some bracing. Doesn't make a huge difference where you go with it, I just put a blue bar to the strongest point in my thinking. Your green bar that goes lower is fine. Or just use Chris's kit (Tangerine). Given that weight is important in your build, I just want to see you only add bracing where it's most effective, and not where it's really superfluous. Attached image(s)
| sixnotfour |
Mar 14 2010, 10:54 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,086 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains
Attached thumbnail(s) |
| Dave_Darling |
Mar 14 2010, 11:54 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,308 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
IIRC, the "Birdcage" Maser was a very early tube-frame design, and not necessarily all that successful I think. You'd probably do much better to check a modern racer, or maybe one of the Sports Racer (e.g., DSR) cars for ideas rather than the Maser.
--DD |
| sixnotfour |
Mar 15 2010, 02:06 AM
(IMG:style_emoticons/default/poke.gif) 200 tubes
| jd74914 |
Mar 15 2010, 07:50 AM
Eh, those are easy joints. They are almost all nice and square. Try this one, its 8 bars into one in the front and 6 into one in the back with about a 1/16" gap for welding. (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/blink.gif) Sorry for the hyjack Dana. I'll use it as an excuse to say that triangles are good, though this frame is overbuilt. Most of the tubes should be .035" wall. For reference, with all 1x.065" tubes this frame weighed 65lbs. ![]() |
| sean_v8_914 |
Mar 15 2010, 04:00 PM
Chingon 601 ![]() ![]() ![]() ![]() Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 |
chop chop!
| sean_v8_914 |
Mar 15 2010, 04:01 PM
how much wire do ya think they used here?
Lo-Fi Version | Time is now: 6th January 2026 - 04:12 PM |
