> How bad is your heat?, Am I chasing a lost cause??
wayne1234
post Mar 10 2010, 05:39 PM
Post #21
So I took off the hearter parts of my parts car and cleaned them all up and painted everything did the drivers side and decided to try it out..... (IMG:style_emoticons/default/sad.gif) tempeture was about 60 outside last night and after running a few minutes the vent was putting out a weak 72 hardley any air movement. the flapper bos is working and in good condition and the dual fan blows out a fair amount of air, but it doesnt seem to make it up front... on chilly mornings and evenings I want some heat and defrost... this wont cut it in my opinion... what else has been done??? I had a crazy idea of a power inverter, and hair dryers behind the speakers, anyone done anything like this??? I have seen 12 volt hair dryers... what else has been done????? or what am I doing wrong ???? I know I have read many complaints about the heat but I had no idea it was that bad...
wayne1234   How bad is your heat?   Mar 10 2010, 05:39 PM
Vacca Rabite   Give it up and get headers. :) heat is over rate...   Mar 10 2010, 05:51 PM
Tom_T   Wayne - A properly operating 914 heat system shou...   Mar 10 2010, 05:52 PM
Triaddave   Mice love to nest in our cars, check to tunnels. d...   Mar 10 2010, 05:54 PM
underthetire   I put a header on, so no heat now, but it used to ...   Mar 10 2010, 06:04 PM
siverson   > A properly operating 914 heat system should t...   Mar 10 2010, 06:07 PM
SirAndy   > A properly operating 914 heat system should ...   Mar 10 2010, 06:15 PM
pbanders   > A properly operating 914 heat system should ...   Mar 11 2010, 12:18 PM
wayne1234   I know all the rear piper are clean and clear.. th...   Mar 10 2010, 06:17 PM
zx-niner   That might be right if you were measuring the temp...   Mar 10 2010, 06:22 PM
orange914   That might be right if you were measuring the tem...   Mar 10 2010, 09:20 PM
pcar916   I'm not that sophisticated. In the winter, I b...   Mar 10 2010, 06:23 PM
wayne1234   By the way what turns on the rear fan??? I have it...   Mar 10 2010, 06:46 PM
SirAndy   By the way what turns on the rear fan??? I have i...   Mar 10 2010, 06:49 PM
wayne1234   ok there is a green wire in the lever it looks lik...   Mar 10 2010, 08:00 PM
Kirmizi   I believe the auxillary fan runs off the same fuse...   Mar 10 2010, 08:14 PM
wayne1234   yep blower works I had it directly to battery for ...   Mar 10 2010, 08:26 PM
Kirmizi   Doh! My bad, just read your fan works... I dri...   Mar 10 2010, 08:28 PM
Kirmizi   Have you tried swapping out the relay with a known...   Mar 10 2010, 08:34 PM
tradisrad   Mine is beyond warm and edging toward too hot when...   Mar 10 2010, 09:44 PM
hot_shoe914   Got to be something wrong with your system. I only...   Mar 10 2010, 09:47 PM
tat2dphreak   don, you were sweating in the garage(at 70) and wo...   Mar 10 2010, 10:04 PM
r_towle   Tip one. Open front hood and remove the paper hose...   Mar 10 2010, 11:05 PM
76-914   Tip one. Open front hood and remove the paper hos...   Mar 11 2010, 09:06 AM
wayne1234   I'm going to try the paint cap thing tomorrow,...   Mar 10 2010, 11:46 PM
Gint   :agree: with the others about 914 heat. If you d...   Mar 11 2010, 07:21 AM
aircooledtechguy   My heater lever is only up just enough to get my i...   Mar 11 2010, 10:51 AM
rhodyguy   in what positions do you have the dash HEAT contro...   Mar 11 2010, 12:24 PM
markb   IIRC, the wires for the heater blower are differen...   Mar 11 2010, 12:43 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 07:03 PM
