what is the length of 914-6 wheel studs? |
tomkirkcis |
Mar 13 2010, 06:38 PM
Newbie Group: Members Posts: 49 Joined: 19-October 06 From: massachusetts Member No.: 7,064 |
Wheel stud length? I am confused as to what is the factory stud length. I seem to be finding conflicting info on the internet. I thought the studs were 45mm . I am installing 10 mm spacers Eric Shea recommended 56mm which would make sense for 8 or 10mm spacers if they are 45mm. Then I found this add on Paragon.
Replace those tired and damaged wheel studs with our new pieces or increase the length for use with spacers. Here's a basic list of sizes used as original: 45mm - 944 83-86, 924S (front); 924S, 944 85.5-89, 944S, 944S2, 944 Turbo, 968 (rear) 50mm - 944 85.5-89, 944S, 944S2, 944 Turbo, 968 (front) 52mm - 911 65-89 (front and rear) 66mm - 911 Turbo 76-89 (front) 66mm - 944 83-85.1 (rear w/factory spacer) 72mm - 911 Turbo 76-89 (rear) A 914-6 isn't listed but I would think it should be the same as a 911 So now I am confused. Anyone know for certain what is the original stud length on a 914-6? Thanks Tom |
carr914 |
Mar 14 2010, 05:10 AM
Racer from Birth Group: Members Posts: 118,670 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
I thought they were the same as the 911 (50-52mm)
I put 72mm on the front and 100mm on my car and use open lugnuts |
ArtechnikA |
Mar 14 2010, 06:18 AM
tomkirkcis |
Mar 14 2010, 08:10 AM
Thanks guys.
I had the 45mm in my head and was just shopping for the right length until I saw the Paragon listing. I think they just have it wrong. I want to stick with the finished look of the alloy lugs so I need to get this right. Thanks again Tom |
Eric_Shea |
Mar 14 2010, 08:27 AM
I believe they have the descriptions mixed up:
45mm - 911 65-89 (front and rear) 50mm - 944 83-86, 924S (front); 924S, 944 85.5-89, 944S, 944S2, 944 Turbo, 968 (rear) 52mm - 944 85.5-89, 944S, 944S2, 944 Turbo, 968 (front) 66mm - 911 Turbo 76-89 (front) 66mm - 944 83-85.1 (rear w/factory spacer) 72mm - 911 Turbo 76-89 (rear) Tom, figure your spacers and, you have roughly 5mm to play with under those aluminum nuts. |
tomkirkcis |
Mar 14 2010, 03:33 PM
I believe they have the descriptions mixed up: 45mm - 911 65-89 (front and rear) 50mm - 944 83-86, 924S (front); 924S, 944 85.5-89, 944S, 944S2, 944 Turbo, 968 (rear) 52mm - 944 85.5-89, 944S, 944S2, 944 Turbo, 968 (front) 66mm - 911 Turbo 76-89 (front) 66mm - 944 83-85.1 (rear w/factory spacer) 72mm - 911 Turbo 76-89 (rear) Tom, figure your spacers and, you have roughly 5mm to play with under those aluminum nuts. What I determined is that 356 uses the same basic stud as a 911 or 914-6. Automotion has a 56mm stud listed as a 356 part that should be great with either the 8 or 10 mm spacers. Tom |
Eric_Shea |
Mar 14 2010, 06:22 PM
Yup... pretty simple. Just add your spacer width to the stock stud. 45+10 = 56mm (IMG:style_emoticons/default/biggrin.gif)
ConeDodger |
Mar 15 2010, 02:45 PM
Apex killer! Group: Members Posts: 23,588 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Yup... pretty simple. Just add your spacer width to the stock stud. 45+10 = 56mm (IMG:style_emoticons/default/biggrin.gif) I'sat Utah math there Big Love? You came up with an extra (in this case) mm... (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/biggrin.gif) |
Eric_Shea |
Mar 15 2010, 06:57 PM
QUOTE You came up with an extra (in this case) mm Gots to. Go-a-search'n for 55's (IMG:style_emoticons/default/wink.gif) (extra's gud) |
Lo-Fi Version | Time is now: 17th May 2024 - 04:13 PM |
