Stopped and Won't Start - '74 2.0 Stock DJet, But all was well and going so great |
Larouex |
Mar 15 2010, 08:00 PM
Larouex Group: Members Posts: 144 Joined: 22-July 08 From: Larouex@gmail.com Member No.: 9,339 Region Association: Pacific Northwest |
I have put a 100 miles on my rebuild for my 2.0, Stock DJet and everything was running great. Now the engine has died and it will not start.
Here is what happened... I was coming around the corner and taking it on my Sunday drive to around 80 MPH and then the engine started to drop acceleration, engine would engage, then buck and then it just ran weakly for a another 100 yards and seemed to not respond to any throttle. Once I pulled over and tried to start it, it was dead. So I walked back to the house (and came back to tow it) it would not start, so I brought it home. Here is what I tested this afternoon to troubleshoot the car...
I seem to be dealing with a fuel problem to the injectors, but things seem to check out. I am now stuck and looking for suggestions from the experts. Larouex |
davesprinkle |
Mar 15 2010, 08:10 PM
Senior Member Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None |
I have put a 100 miles on my rebuild for my 2.0, Stock DJet and everything was running great. Now the engine has died and it will not start. Here is what happened... I was coming around the corner and taking it on my Sunday drive to around 80 MPH and then the engine started to drop acceleration, engine would engage, then buck and then it just ran weakly for a another 100 yards and seemed to not respond to any throttle. Once I pulled over and tried to start it, it was dead. So I walked back to the house (and came back to tow it) it would not start, so I brought it home. Here is what I tested this afternoon to troubleshoot the car...
I seem to be dealing with a fuel problem to the injectors, but things seem to check out. I am now stuck and looking for suggestions from the experts. Larouex Verify that your injector points are working. |
Larouex |
Mar 19 2010, 09:23 PM
Well I swapped in another dizzy and trigger points are all working, still dead. Plugs are dry. It makes me think I am still chasing a fuel problem of some kind and the failure was so quick and it stumping me.
Question. I am going to pull the injectors, what should I check and test into baby jars as far as how much fuel should be coming out, etc.? I have at least 2 of every part for a DJet, so I will start testing, but this is frustrating and worse, I cannot trust this kind of failure if I am far from home, hell it might push me to carbs <shudder/> |
ConeDodger |
Mar 19 2010, 09:30 PM
Apex killer! Group: Members Posts: 23,588 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Make sure your CHT is connected. In fact chase down all the EFI connections. Some of them will shut down the engine if they are pulled.
Make sure if your tin is late model and you have mounted the coil to the tin that the coil hasn't rotated and shorted out against the tin. |
Larouex |
Mar 20 2010, 07:54 PM
Well, all the symptoms did not lead to me t-shoot to the root cause. What ended up getting it running was swapping in a MPS unit. Then it started right up, it was the last thing I tried as it was a rebuilt unit and I just did the pbanders verification with a vacuum pull and testing of resistance values when I put the engine in just a 100 miles ago, dang!
I will do a verification on the failed MPS in the next few days and I post what I learned. Sadly, this is my last good MPS for a 2.0 and after the last reman POC I ordered, I need to find a backup. Larouex |
john grier |
Mar 20 2010, 07:59 PM
Member Group: Members Posts: 303 Joined: 27-June 04 From: Hermitage, Tn Member No.: 2,265 Region Association: South East States |
Well I am not an expert, but
what about something simple like the condenser maybe the wires broke John |
john grier |
Mar 20 2010, 08:09 PM
I add this because the same thing happened to my 74
three years ago. like you said went around a curve and the car died. After checking all the major stuff, witch was fine, came down to checking the condenser, The wires had broken off. (IMG:style_emoticons/default/headbang.gif) Simple lesson I learned Check the easy stuff first, not the hard. |
Larouex |
Mar 20 2010, 09:22 PM
I add this because the same thing happened to my 74 three years ago. like you said went around a curve and the car died. After checking all the major stuff, witch was fine, came down to checking the condenser, The wires had broken off. (IMG:style_emoticons/default/headbang.gif) Simple lesson I learned Check the easy stuff first, not the hard. Sure, I am pretty disciplined so I went through things carefully and one at a time, try it test and then move on <g/> I appreciate your response. It really was a MPS failure and I reproduced it swapping the part in and testing it. Larouex |
Bleyseng |
Mar 21 2010, 04:44 AM
So the mps shorted out or had a vacuum failure?
Lo-Fi Version | Time is now: 17th May 2024 - 05:21 PM |
