Simplyfied rear toe adjustment ... |
Mar 18 2010, 01:04 PM
Resident German Group: Admin Posts: 41,675 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
$239.95/pair simpler? (IMG:style_emoticons/default/popcorn[1].gif) |
914werke |
Mar 18 2010, 03:46 PM
"I got blisters on me fingers" Group: Members Posts: 10,138 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Uh..vs $320.00 from Patrick? (IMG:style_emoticons/default/confused24.gif) & no need to remove Rockers to perform adjustments. (IMG:style_emoticons/default/screwy.gif) |
jt914-6 |
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
(IMG:style_emoticons/default/agree.gif) Unless you're racing a lot, how many times do you adjust the toe on street/autox/de cars? Putting the heim joints on isn't expensive and works. |
ArtechnikA |
Mar 18 2010, 03:54 PM
assumes you can source, fabricate, and mount the external toe-link for $0, which I don't believe many people can... It appears the external link may provide some reinforcement which the big-HP, big-tire people could use. If you just want quick toe adjustment, the Tangerine parts look quite nice. I believe the real total installed cost is going to be pretty close either way. |
Mar 18 2010, 03:57 PM
Uh..vs $320.00 from Patrick? (IMG:style_emoticons/default/confused24.gif) No... Never said a word about PMS ... I bet one can build a setup like the one pictured in my initial post for a lot less than $240. And i have no idea why you think that one needs to remove the rocker panels to do the adjusting. On my 914, there's plenty of space to get a wrench in there. (IMG:style_emoticons/default/shades.gif) Andy |
914werke |
Mar 18 2010, 04:40 PM
Uh..vs $320.00 from Patrick? (IMG:style_emoticons/default/confused24.gif) No... Never said a word about PMS ... I bet one can build a setup like the one pictured in my initial post for a lot less than $240. And i have no idea why you think that one needs to remove the rocker panels to do the adjusting. On my 914, there's plenty of space to get a wrench in there. (IMG:style_emoticons/default/shades.gif) Andy No Eric did. I dont disagree the average joe might be able source the parts for less than that, but then you have to weld-up, not only the body, but the stamped steel spot welded mounting ears, w/o distorting the sh*t out of them. Not something the avg. Joe has skill or access to. My point was, while agreeing that the application of toe adj. was a good one, I tend agree w/Rich that it may end up costing near the same as a BOLT-ON solution. I have no experience with ease of adjustment of that setup I was just responding to a previous comment. K.I.S.S. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 7th June 2024 - 02:30 PM |
