Renegade SBC V8 kit, $990. |
914ltd |
Mar 16 2010, 08:43 PM
Member Group: Members Posts: 239 Joined: 18-April 03 From: Peoria, IL Member No.: 581 Region Association: None |
This is a near complete kit to install a smallblock Chevy engine in a 914. I have collected these parts in anticipation of building another V8 car but am now ready to sell. The Kennedy 215mm disc and pressure plate, 911SC starter, rams horn exhaust manifolds and the radiator (dented but not leaking) are used parts. Most everything else is new.
New parts: Water pump housing and a big block Chrysler water pump. Aluminum brackets for mounting the water pump and Chevy alternator. Remachined new flywheel for the 215 Kennedy clutch. Pilot bearing mount. Engine mount bar. 2 transmission mount adaptors for setting the engine back making it unnecessary to cut into the firewall. Several feet of new 1 1/4” and 1’ Gates green stripe radiator hose. Adaptors to connect the water pump to the front of the Chevy engine, water outlet elbows are included but not shown. No hoses for these. Bracket for mounting the throttle cable. Required Chevy crankshaft pulley. Thermostat housing with elbow. Package of new hardware, nuts, bolts etc. Renegade original instructions. This package is probably not complete but not much else should be required besides engine and exhaust system. $990. Plus shipping and $3.00 per box handling. Brad Mayeur, Peoria, Il. 309-694-1797 Attached image(s) |
914ltd |
Mar 16 2010, 08:45 PM
more pix
Attached image(s) |
Andyrew |
Mar 16 2010, 11:00 PM
Only thing I could think of that you need is the bolts. Flywheel bolts are special (low profile).
The harmonic balancer needs a 1/8" spacer, Rennegade has it. The shift linkage needs to be extended 1" to accept the trani moving back. Honest complete kit. Great price! Good luck with the sale. |
Lo-Fi Version | Time is now: 20th May 2024 - 11:11 AM |
