Weber IDF Throttle Lever Loose |
tornik550 |
Mar 17 2010, 09:11 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
Over the past few months, I have been renovating my carbs and linkage. All carb and link parts are new. Now that everything is installed, the throttle lever is loose on the throttle shaft (this was also the way it was prior to the renovation- this is part of the reason for the renovation). This is obviously not good for calibration and such. If I tighten the nut that holds the throttle lever to the throttle shaft more, the throttle shaft doesn't rotate.
I realize there is probably an easy answer. Please let me know what I am missing. Thank you |
Lo-Fi Version | Time is now: 17th May 2024 - 02:18 PM |
