Mirror mounting screw spacing, what is the measurement, please |
DanT |
Mar 18 2010, 08:48 PM
need to know the spacing of the screws for the stock outside rearview mirror mounting.
center to center thanks |
Tom_T |
Mar 18 2010, 09:06 PM
Dan, there should be 2 threaded receivers on the underside of the door skin top where the mirror mounts. If you're doing the pass side on one not previously mounted, then you take off the interior door panels to see where they are & punch/drill out the top door skin where they are located.
IIRC - Pelican tech section has an article on that, as well as in Paternie's "How to Restore & Modify Your Porsche 914/914-6" book. If you're just checking the spacing, measure off the stock mirror base plate. |
DanT |
Mar 18 2010, 09:21 PM
I am aware of the captured nuts on the inside of each door skin...
If I had a door here with me or a stock mirror I would have measured it already. I am trying to modify some other mirrors and don't have a door or mirror at home to measure. (IMG:style_emoticons/default/smile.gif) All of my previous 914s had passenger side mirrors mounted by myself...in the stock location |
Sleepin |
Mar 18 2010, 09:45 PM
Advanced Member Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains |
just measured one....30.00 mm center to center.
DanT |
Mar 18 2010, 09:51 PM
just measured one....30.00 mm center to center. thank you very much (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 04:42 PM |
