Removing bumper pads |
dank |
Mar 19 2010, 02:34 AM
DanielK Group: Members Posts: 25 Joined: 8-March 10 From: Mountain View, CA Member No.: 11,440 Region Association: None |
Sorry if it's a dumb question, but how difficult is it to separate the front/rear bumper pads from the chrome they sit on (pre-'75)? Is it just a screw?
ellisor3 |
Mar 19 2010, 04:36 AM
HPWhore Group: Members Posts: 811 Joined: 23-October 08 From: Fleming Island, Florida Member No.: 9,683 Region Association: South East States |
EdwardBlume |
Mar 19 2010, 06:45 AM
Soak them with whatever penetrating oil you have and good luck.. |
Joe Bob |
Mar 19 2010, 06:58 AM
The pads on the top? If so, penetration oil overnight, tigten first then back them off. They will snap suddenly so be gentle. I've repaired a few be installing an insert then using a bolt in replacement. No one sees the repair as it's inside the bumper.
Mikey914 |
Mar 19 2010, 12:04 PM
The rubber man Group: Members Posts: 12,668 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
If they break you can use epoxy and stainless bolts to repair. This could last awhile if your not in a wet environment, but rust never sleeps.
Tom_T |
Mar 19 2010, 02:22 PM
Sorry if it's a dumb question, but how difficult is it to separate the front/rear bumper pads from the chrome they sit on (pre-'75)? Is it just a screw? 70-74 bumper top pads are the threaded studs thru top flanges of the bumpers, with ehx nuts as noted above. 73 - F & 74 F&R bumper gaurds ("Tits") are 2 of those studs with hex bolts through the face of the bumpers & the reinforcing braces on the backside. Whether you mean top pads or tits - if they're not frozen, then they'll come off easily; & if there is any corrosion visible or if stuck, then use the suggested penetrating oil method suggested above by Rob & Rico. NO (IMG:style_emoticons/default/smash.gif) !! (IMG:style_emoticons/default/biggrin.gif) |
Hammy |
Mar 19 2010, 02:31 PM
Lo-Fi Version | Time is now: 17th May 2024 - 02:53 PM |
